[mapserver-dev] c unit tests in MapServer
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Thu Dec 4 12:34:23 PST 2014
First, thanks so much for your willingness to report/research/fix bugs - it's invaluable.
I don't know that we'd need to make the full leap to a C Unit testing framework to make use of them on a ticket by ticket basis. If you wanted to roll a simple C program that tests just the function in question I'd certainly want to use it. It makes sense in this case. So often though bugs seem to involve a series of functions performing a complex operation where a more complete configuration (e.g. data+mapfile) and request is necessary to trigger the issue.
Steve
From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of geographika
Sent: Wednesday, December 03, 2014 8:56 AM
To: mapserver-dev at lists.osgeo.org
Subject: [mapserver-dev] c unit tests in MapServer
Hi list,
With almost 20 years of development, the MapServer codebase can be overwhelming at first. For most open source projects I've found the easiest way into helping with a project is:
1. Reporting bugs
2. Finding the problematic code
3. Submitting a patch and unit test.
In 2006 there was a Request For Comments (#12) by Umberto Nicoletti about adding C Unit tests:
http://www.mapserver.org/development/rfc/ms-rfc-12.html
Also see GitHub issue #1664: https://github.com/mapserver/mapserver/issues/1664
Obviously a full test suite of existing code isn't possible, however if the testing framework and skeleton folder/file structure was set up it may help more concrete contributions from developers outside of the core MapServer team.
There have been a few bugs I've submitted where I would feel comfortable adding a unit test to an existing file to show the error, but creating full msautotest examples seems very daunting. As a concrete example while testing the latest dev build I noticed the msParseTime function in the maptime.c module threw an error. Unit tests for this function seem like the perfect solution for these types of bugs, and to avoid breaking changes in the future.
https://github.com/mapserver/mapserver/commit/0cc47e3027a75cf18c5310694877999c6b245371
C Unit tests have come up a few times in the past e.g. Paul Ramsey's post about PostGIS driver testing: http://osgeo-org.1560.x6.nabble.com/cunit-RFC-12-td4261340.html
Frank Warmerdam's response (in 2008) was -
My preference remains to test specific functions as part of a larger
operations since we already have such technology in place (ie. msautotest)
or to expose the functionality through mapscript and use mapscript tests
like Sean's python unit tests.
I do not feel that introducing another testing methodology into the
project would be wise.
The Python unit tests are again useful, but require testing against full builds, a difficult task for those not familiar with make files and gathering dependencies.
Testing database drivers as I understand it would require a full test database setup with msautotest, whereas for many bugs it is clear which function needs modifying and a unit test could be added quickly to highlight and help fix the bug.
I've only experience in Python and .NET unit testing so perhaps C testing is more trouble than it is worth.
I guess it is up to the core devs whether it has any benefit to themselves, or the project as a whole, whether this issue should be reconsidered.
Regards,
Seth
web: http://geographika.co.uk
twitter: @geographika
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20141204/9a864ffc/attachment.html>
