[mapserver-dev] RFC 112: offset FOLLOW labels when self collisions are detected
Stephan Meißl
stephan at meissl.name
Fri Dec 12 02:04:29 PST 2014
+1 and +1 as well.
cu
Stephan
On 12/12/2014 12:13 AM, Lime, Steve D (MNIT) wrote:
> Configuration could always be added later if it is determined to be necessary. I agree that not having to fiddle is a good thing and lessens the learning curve.
> So, I'm +1 for the RFC "as is" and +1 for including in 7.0.
> Steve
> -----Original Message-----
> From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Stephen Woodbridge
> Sent: Wednesday, December 10, 2014 8:31 AM
> To: mapserver-dev at lists.osgeo.org
> Subject: Re: [mapserver-dev] RFC 112: offset FOLLOW labels when self collisions are detected
> On 12/10/2014 3:49 AM, thomas bonfort wrote:
>> Hi Devs,
>> Please have a look at
>> http://mapserver.org/development/rfc/ms-rfc-112.html
>> The RFC is very short and contains an open question as to whether the
>> proposed behavior should be configurable or not (I don't think it
>> needs to be) Given how much the 7.0 release has slipped already, and
>> the limited implications of the change, I would like this to be
>> applied to master before we create 7.0 stable branch.
> This sounds reasonable to me. I like being able to configure things, but I like it better when they just work nicely without a lot of fiddling because it makes it a lot easier for users. So unless there is some great need to have additional configuration parameters I would leave them out.
> Thanks,
> -Steve W
