[mapserver-dev] FW: License of librsvg
Martin.Icking at bentley.com Martin.Icking at bentley.com
Tue Jan 7 01:17:57 PST 2014
In the meantime I've got a precise answer from one of the librsvg authors - see below. So the librsvg library is LGPL-licensed - so no issue to use it by MapServer.
Best regards
Martin
-----Original Message-----
Sent: Montag, 6. Januar 2014 14:54
To: Martin Icking
Subject: Re: License of librsvg
Hi;
Am Mon, 2 Dec 2013 16:25:00 +0000
schrieb <Martin.Icking >:
> Hi Christian,
> librsvg is listed as being dual licensed (GPL and LGPL) in Wikipedia
> and in the sources we see two files COPYING (GPL) and COPYING.LIB
> (LGPL). So can we handle librsvg as being LGPL'ed? If yes I'd suggest
> to change the Appendix A of the "RSVG Library Reference
> Manual<https://developer.gnome.org/rsvg/2.40/licence.html>" which
> mentions only the GPL license. Thanks Martin
The licence mentioned in the manual is the manual's licence. The manual is a combination of GPL text and pulling in lots of LGPL text (from the source code gtk-doc comments) so the aggregate is GPL. The library itself is purely LGPL. Maybe the manual should make that clearer... see
https://bugzilla.gnome.org/show_bug.cgi?id=692425 .
Regards,
	C. Persch
