[mapserver-dev] MapServer compilation
Armand Bahi
armand.bahi at imerir.com
Thu Jan 9 07:34:31 PST 2014
Hello,
I'm trying to compile mapserver 6.4.1 with CMake, and without JPEG and PNG
libraries.
This is the CMake error :
CMake Error at CMakeLists.txt:55 (message):
PNG library/component could not be found and is a mandatory dependency
HINT:
- add the PNG install directory to the CMAKE_PREFIX_PATH variable
(-DCMAKE_PREFIX_PATH="/path/to/PNG-install-dir;/path/to/other/dirs"
Call Stack (most recent call first):
CMakeLists.txt:281 (report_mandatory_not_found)
Could NOT find JPEG (missing: JPEG_LIBRARY JPEG_INCLUDE_DIR)
JPEG library/component could not be found and is a mandatory dependency
HINT:
- add the JPEG install directory to the CMAKE_PREFIX_PATH variable
(-DCMAKE_PREFIX_PATH="/path/to/JPEG-install-dir;/path/to/other/dirs"
CMakeLists.txt:290 (report_mandatory_not_found)
Why I can tell to CMake for don't try to load this libs ?
PS : If I delete lines upon from CMakeLists.txt, the cofigure is done
find_package(PNG)
if(PNG_FOUND)
include_directories(${PNG_INCLUDE_DIR})
ms_link_libraries( ${PNG_LIBRARIES})
set(USE_PNG 1)
else(PNG_FOUND)
report_mandatory_not_found(PNG)
endif(PNG_FOUND)
find_package(JPEG)
if(JPEG_FOUND)
include_directories(${JPEG_INCLUDE_DIR})
ms_link_libraries( ${JPEG_LIBRARY})
set(USE_JPEG 1)
else(JPEG_FOUND)
report_mandatory_not_found(JPEG)
endif(JPEG_FOUND)
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20140109/ca38d57b/attachment.html>
