[mapserver-dev] MapServer compilation
thomas.bonfort at gmail.com
Thu Jan 9 07:36:58 PST 2014
Armand,
As the error message states, they are a mandatory dependency and cannot be disabled.
thomas
On 9 janv. 2014, at 16:34, Armand Bahi <armand.bahi at imerir.com> wrote:
> Hello,
> I'm trying to compile mapserver 6.4.1 with CMake, and without JPEG and PNG libraries.
> This is the CMake error :
> CMake Error at CMakeLists.txt:55 (message):
> PNG library/component could not be found and is a mandatory dependency
> HINT:
> - add the PNG install directory to the CMAKE_PREFIX_PATH variable (-DCMAKE_PREFIX_PATH="/path/to/PNG-install-dir;/path/to/other/dirs"
> Call Stack (most recent call first):
> CMakeLists.txt:281 (report_mandatory_not_found)
> Could NOT find JPEG (missing: JPEG_LIBRARY JPEG_INCLUDE_DIR)
> JPEG library/component could not be found and is a mandatory dependency
> HINT:
> - add the JPEG install directory to the CMAKE_PREFIX_PATH variable (-DCMAKE_PREFIX_PATH="/path/to/JPEG-install-dir;/path/to/other/dirs"
> CMakeLists.txt:290 (report_mandatory_not_found)
> Why I can tell to CMake for don't try to load this libs ?
> PS : If I delete lines upon from CMakeLists.txt, the cofigure is done
> find_package(PNG)
> if(PNG_FOUND)
> include_directories(${PNG_INCLUDE_DIR})
> ms_link_libraries( ${PNG_LIBRARIES})
> set(USE_PNG 1)
> else(PNG_FOUND)
> report_mandatory_not_found(PNG)
> endif(PNG_FOUND)
> find_package(JPEG)
> if(JPEG_FOUND)
> include_directories(${JPEG_INCLUDE_DIR})
> ms_link_libraries( ${JPEG_LIBRARY})
> set(USE_JPEG 1)
> else(JPEG_FOUND)
> report_mandatory_not_found(JPEG)
> endif(JPEG_FOUND)
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
