[mapserver-dev] Error building Mapserver 6.4.1 with fribidi
samuelmesa at gmail.com
Fri Jan 24 10:16:49 PST 2014
Thank you Thomas for the prompt response and solution. However, only ran
compilation, with quotes on the routes of FriBiDi, adding another route to
the header of glibconfig.h.
-DFRIBIDI_INCLUDE_DIR="/usr/include/glib-2.0;/usr/lib/glib-2.0/include;/usr/include/fribidi"
I've updated the Mapserver package for users of Archilinux [1].
Thanks again for your prompt response,
Samuel.
[1] https://aur.archlinux.org/packages/mapserver/
2014/1/24 thomas bonfort <thomas.bonfort at gmail.com>
> Try running cmake again with
> -DFRIBIDI_INCLUDE_DIR=/usr/include/glib-2.0;/usr/include/fribidi
> those should normally have been set by pkg-config. what's the output of
> pkg-config --cflags fribidi
> thomas
> On 24 Jan 2014, at 18:40, samuelmesa at gmail.com wrote:
> > Thomas, the glib.h header exists in /usr/include/glib-2.0/glib.h.
> However, I do not see the way to include the path in the CMake, since there
> is no variable as GLIB_INCLUDE_DIR.
> > I have disabled this option in Archlinux package, however I'd like other
> users to achieve set it, if they needed Fribidi.
> > Thank you
> > Samuel.
> > 2014/1/24 Thomas Bonfort <thomas.bonfort at gmail.com>
> > is the glib.h header available on your system ?
> > On 23/01/2014 19:02, samuelmesa at gmail.com wrote:
> > > Hi all, I'm trying to update the package Mapserver version 6.4.1 [1]
> for
> > > Archlinux, however reports the following error during compilation:
> > > "/usr/include/fribidi/fribidi-common.h: 61:20: fatal error: glib.h: No
> such
> > > file or directory
> > > # Include <glib.h>"
> > > The PKGBUILD file is [2] and is fribidi version is 0.19.6 and glib2
> version
> > > is 2.38.2.
> > > How I can fix this compilation error?
> > > Regards,
> > > Samuel Mesa
> > > [2] https://aur.archlinux.org/packages/ma/mapserver/PKGBUILD
> > > _______________________________________________
> > > mapserver-dev mailing list
> > > mapserver-dev at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
> > / v \
/ v \
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20140124/0dfeac77/attachment.html>
