[mapserver-dev] Raster fliped with WMS and reprojection
Yves Jacolin yves.jacolin at camptocamp.com
Thu Jun 12 05:27:30 PDT 2014
Again,
About vertical blank line, one should add this line in the layer object
(this is not in the doc):
PROCESSING "LOAD_WHOLE_IMAGE=YES"
See https://github.com/mapserver/mapserver/issues/3111
Y.
2014-06-12 14:12 GMT+02:00 Yves Jacolin <yves.jacolin at camptocamp.com>:
> Hello,
> I have a raster file in GeoTiff, EPSG:4326. I am using it in a mapfile for
> WMS services in EPSG:3857.
> When zooming out I get the raster layer flipped. All other vector layer
> are ok. It seems that it occurs when the BBOX is outside the EPSG:3857 projected
> bounds limitation [1].
> I have another issue which may not be linked with the previous one: a
> vertical blank line appear on the left (beyon 180 degrees). However, the
> raster is showing again after the date line.
> Here two requests, the first one shows the wrong result:
> http://www.ifremer.fr/services/wms1?LAYERS=ETOPO1_BATHY_R&STYLES=default&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&SRS=EPSG%3A3857&BBOX=-28066452.007098,-2465552.6274048,30754589.246699,9979617.7775904&WIDTH=1503&HEIGHT=400
> The second one shows the good result:
> http://www.ifremer.fr/services/wms1?LAYERS=ETOPO1_BATHY_R&STYLES=default&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&SRS=EPSG%3A3857&BBOX=-28066452.007098,-2465552.6274048,30754589.246699,9979617.7775904&WIDTH=1502&HEIGHT=400
> Diff:
> - WIDTH=1503
> + WIDTH=1502
> This MapServer is quiet old but I can reproduce the issue with master.
> If I open the raster file directly in QGIS I have some other rendering
> issue (some part of the raster are not displayed at all, but always
> different part among the zoom level (always on the left anyway).
> Log in MapServer doesn't seems to show any error.
> Any idea? Should I fill a ticket with this?
> Thanks,
> Y.
> [1] http://epsg.io/3857
> Responsable Formation et Support
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel (France) : +33 4 79 26 57 98
> Tel (Suisse) : 021 619 10 43
> Mob. : +33 6 18 75 42 21
> Fax : 04 79 70 15 81
> Mail : yves.jacolin at camptocamp.com
> http://www.camptocamp.com
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20140612/5c84bbbe/attachment.html>
