[mapserver-dev] Raster fliped with WMS and reprojection
Yves Jacolin
yves.jacolin at camptocamp.com
Thu Jun 12 05:12:58 PDT 2014
Hello,
I have a raster file in GeoTiff, EPSG:4326. I am using it in a mapfile for
WMS services in EPSG:3857.
When zooming out I get the raster layer flipped. All other vector layer are
ok. It seems that it occurs when the BBOX is outside the EPSG:3857 projected
bounds limitation [1].
I have another issue which may not be linked with the previous one: a
vertical blank line appear on the left (beyon 180 degrees). However, the
raster is showing again after the date line.
Here two requests, the first one shows the wrong result:
http://www.ifremer.fr/services/wms1?LAYERS=ETOPO1_BATHY_R&STYLES=default&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&SRS=EPSG%3A3857&BBOX=-28066452.007098,-2465552.6274048,30754589.246699,9979617.7775904&WIDTH=1503&HEIGHT=400
The second one shows the good result:
http://www.ifremer.fr/services/wms1?LAYERS=ETOPO1_BATHY_R&STYLES=default&FORMAT=image%2Fpng&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&SRS=EPSG%3A3857&BBOX=-28066452.007098,-2465552.6274048,30754589.246699,9979617.7775904&WIDTH=1502&HEIGHT=400
Diff:
- WIDTH=1503
+ WIDTH=1502
This MapServer is quiet old but I can reproduce the issue with master.
If I open the raster file directly in QGIS I have some other rendering
issue (some part of the raster are not displayed at all, but always
different part among the zoom level (always on the left anyway).
Log in MapServer doesn't seems to show any error.
Any idea? Should I fill a ticket with this?
Thanks,
Y.
[1] http://epsg.io/3857
Responsable Formation et Support
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel (France) : +33 4 79 26 57 98
Tel (Suisse) : 021 619 10 43
Mob. : +33 6 18 75 42 21
Fax : 04 79 70 15 81
Mail : yves.jacolin at camptocamp.com
http://www.camptocamp.com
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20140612/4f9df0ba/attachment.html>
