[mapserver-dev] missing files using built-in OpenLayers template
Jeff McKenna jmckenna at gatewaygeomatics.com
Mon Jun 16 06:06:45 PDT 2014
Oh interesting, I've never had to set that with single file builds..will
try now thanks!
-jeff
On 2014-06-16, 10:01 AM, thomas bonfort wrote:
> OpenLayers.ImgPath should probably be set to
> "http://www.mapserver.org/lib/" in our generated JS.
> On 16 June 2014 14:58, Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
>> Hi THomas,
>> Yes in fact I placed those files there this morning, the 'img' and
>> 'theme' folders were missing.
>> Correct, this single file build does not seem to be properly looking for
>> those files, it should be looking right in the same folder.
>> -jeff
>> On 2014-06-16, 9:55 AM, thomas bonfort wrote:
>>> Jeff,
>>> The files are present now (c.f.
>>> http://www.mapserver.org/lib/theme/default/) however there's something
>>> wrong with our generated javascript as it's requesting the theme files
>>> from http://server/cgi-bin/theme/default/style.css instead of
>>> www.mapserver.org/lib/...
>>> On 16 June 2014 14:27, Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
>>>> Still no luck, I would have thought that this OpenLayers single build
>>>> would look in the same directory for the img and theme folders.  Anyone
>>>> have any ideas?
>>>> -jeff
>>>> On 2014-06-16, 9:09 AM, Jeff McKenna wrote:
>>>>> Oh ok great, thanks for confirming this Lars, I thought I was going crazy :)
>>>>> I have no idea how the website and github are linked now, but I just
>>>>> poked around the ProjectsVM and found that js file, so I copied the img
>>>>> and theme folders there: http://www.mapserver.org/lib/  ...but still no
>>>>> luck.  Will keep looking.
>>>>> -jeff
>>>>> On 2014-06-16, 5:47 AM, Schylberg Lars wrote:
>>>>>> You are right Jeff,
>>>>>> The openlayers script was missing in April and I asked that it would be put back.
>>>>>> It was recoverd but unfortunally the small images was not put back.
>>>>>> I started to use a local copy at the same time so I forgot to mention that as well.
>>>>>> /Lars S.
>>>>>> -----Original Message-----
>>>>>> From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Jeff McKenna
>>>>>> Sent: den 16 juni 2014 00:32
>>>>>> To: 'MapServer Dev Mailing List'
>>>>>> Subject: [mapserver-dev] missing files using built-in OpenLayers template
>>>>>> Hello all,
>>>>>> I have hit a wall, and I am hoping someone can confirm my suspicions.
>>>>>> When using the built-in OpenLayers template (http://mapserver.org/development/rfc/ms-rfc-63.html), I believe there are some missing "img" and "theme" folders on the server where the OpenLayers-ms60.js file lives: http://mapserver.org/lib/
>>>>>> If I test the CGI with MODE=browse&TEMPLATE=openlayers, my map will always appear, I can zoom/pan, but the OpenLayers control images (zoom,
>>>>>> pan) are broken.  Firebug is looking for them at something like 127.0.0.1/cgi-bin/img/north-mini.png and 127.0.0.1/cgi-bin/theme/default/style.css
>>>>>> Looking at http://mapserver.org/lib/ I see that the OL file was modified on April 15th...I wonder if this has to do with the server changes, and possibly those img/style folders were not moved?
>>>>>> Or put another way: can anyone else see the zoom/pan images now when trying mode=browse&template=openlayers ??
>>>>>> Thanks all!
>>>>>> -jeff
>>>>>> PS. it would be odd if I am the first person to notice this in 2 months!!!
>>>>>> _______________________________________________
>>>> mapserver-dev mailing list
>>>> mapserver-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>> Jeff McKenna
>> MapServer Consulting and Training Services
>> http://www.gatewaygeomatics.com/
Jeff McKenna
