[mapserver-dev] missing files using built-in OpenLayers template
thomas bonfort thomas.bonfort at gmail.com
Mon Jun 16 06:01:51 PDT 2014
OpenLayers.ImgPath should probably be set to
"http://www.mapserver.org/lib/" in our generated JS.
On 16 June 2014 14:58, Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
> Hi THomas,
> Yes in fact I placed those files there this morning, the 'img' and
> 'theme' folders were missing.
> Correct, this single file build does not seem to be properly looking for
> those files, it should be looking right in the same folder.
> -jeff
> On 2014-06-16, 9:55 AM, thomas bonfort wrote:
>> Jeff,
>> The files are present now (c.f.
>> http://www.mapserver.org/lib/theme/default/) however there's something
>> wrong with our generated javascript as it's requesting the theme files
>> from http://server/cgi-bin/theme/default/style.css instead of
>> www.mapserver.org/lib/...
>> On 16 June 2014 14:27, Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
>>> Still no luck, I would have thought that this OpenLayers single build
>>> would look in the same directory for the img and theme folders.  Anyone
>>> have any ideas?
>>> -jeff
>>> On 2014-06-16, 9:09 AM, Jeff McKenna wrote:
>>>> Oh ok great, thanks for confirming this Lars, I thought I was going crazy :)
>>>> I have no idea how the website and github are linked now, but I just
>>>> poked around the ProjectsVM and found that js file, so I copied the img
>>>> and theme folders there: http://www.mapserver.org/lib/  ...but still no
>>>> luck.  Will keep looking.
>>>> -jeff
>>>> On 2014-06-16, 5:47 AM, Schylberg Lars wrote:
>>>>> You are right Jeff,
>>>>> The openlayers script was missing in April and I asked that it would be put back.
>>>>> It was recoverd but unfortunally the small images was not put back.
>>>>> I started to use a local copy at the same time so I forgot to mention that as well.
>>>>> /Lars S.
>>>>> -----Original Message-----
>>>>> From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Jeff McKenna
>>>>> Sent: den 16 juni 2014 00:32
>>>>> To: 'MapServer Dev Mailing List'
>>>>> Subject: [mapserver-dev] missing files using built-in OpenLayers template
>>>>> Hello all,
>>>>> I have hit a wall, and I am hoping someone can confirm my suspicions.
>>>>> When using the built-in OpenLayers template (http://mapserver.org/development/rfc/ms-rfc-63.html), I believe there are some missing "img" and "theme" folders on the server where the OpenLayers-ms60.js file lives: http://mapserver.org/lib/
>>>>> If I test the CGI with MODE=browse&TEMPLATE=openlayers, my map will always appear, I can zoom/pan, but the OpenLayers control images (zoom,
>>>>> pan) are broken.  Firebug is looking for them at something like 127.0.0.1/cgi-bin/img/north-mini.png and 127.0.0.1/cgi-bin/theme/default/style.css
>>>>> Looking at http://mapserver.org/lib/ I see that the OL file was modified on April 15th...I wonder if this has to do with the server changes, and possibly those img/style folders were not moved?
>>>>> Or put another way: can anyone else see the zoom/pan images now when trying mode=browse&template=openlayers ??
>>>>> Thanks all!
>>>>> -jeff
>>>>> PS. it would be odd if I am the first person to notice this in 2 months!!!
>>>>> _______________________________________________
>>> mapserver-dev mailing list
>>> mapserver-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
