[mapserver-dev] missing files using built-in OpenLayers template
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Jun 16 06:19:08 PDT 2014
I had already changed the ImgPath, and I clear my cache constantly..no
this ImgPath change is in fact needed in our case for some reason. (Now
i'm battling the missing style path also). Looking...
-jeff
On 2014-06-16, 10:16 AM, thomas bonfort wrote:
> hmm, I was wondering why that wasn't needed beforehand. Actually the
> viewer works correctly with the lib files you added this morning, just
> make sure your browser cache is purged.
> thomas
> On 16 June 2014 15:06, Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
>> Oh interesting, I've never had to set that with single file builds..will
>> try now thanks!
>> -jeff
>> On 2014-06-16, 10:01 AM, thomas bonfort wrote:
>>> OpenLayers.ImgPath should probably be set to
>>> "http://www.mapserver.org/lib/" in our generated JS.
>>> On 16 June 2014 14:58, Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
>>>> Hi THomas,
>>>> Yes in fact I placed those files there this morning, the 'img' and
>>>> 'theme' folders were missing.
>>>> Correct, this single file build does not seem to be properly looking for
>>>> those files, it should be looking right in the same folder.
>>>> -jeff
>>>> On 2014-06-16, 9:55 AM, thomas bonfort wrote:
>>>>> Jeff,
>>>>> The files are present now (c.f.
>>>>> http://www.mapserver.org/lib/theme/default/) however there's something
>>>>> wrong with our generated javascript as it's requesting the theme files
>>>>> from http://server/cgi-bin/theme/default/style.css instead of
>>>>> www.mapserver.org/lib/...
>>>>> On 16 June 2014 14:27, Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
>>>>>> Still no luck, I would have thought that this OpenLayers single build
>>>>>> would look in the same directory for the img and theme folders. Anyone
>>>>>> have any ideas?
>>>>>> -jeff
>>>>>> On 2014-06-16, 9:09 AM, Jeff McKenna wrote:
>>>>>>> Oh ok great, thanks for confirming this Lars, I thought I was going crazy :)
>>>>>>> I have no idea how the website and github are linked now, but I just
>>>>>>> poked around the ProjectsVM and found that js file, so I copied the img
>>>>>>> and theme folders there: http://www.mapserver.org/lib/ ...but still no
>>>>>>> luck. Will keep looking.
>>>>>>> -jeff
>>>>>>> On 2014-06-16, 5:47 AM, Schylberg Lars wrote:
>>>>>>>> You are right Jeff,
>>>>>>>> The openlayers script was missing in April and I asked that it would be put back.
>>>>>>>> It was recoverd but unfortunally the small images was not put back.
>>>>>>>> I started to use a local copy at the same time so I forgot to mention that as well.
>>>>>>>> /Lars S.
>>>>>>>> -----Original Message-----
>>>>>>>> From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Jeff McKenna
>>>>>>>> Sent: den 16 juni 2014 00:32
>>>>>>>> To: 'MapServer Dev Mailing List'
>>>>>>>> Subject: [mapserver-dev] missing files using built-in OpenLayers template
>>>>>>>> Hello all,
>>>>>>>> I have hit a wall, and I am hoping someone can confirm my suspicions.
>>>>>>>> When using the built-in OpenLayers template (http://mapserver.org/development/rfc/ms-rfc-63.html), I believe there are some missing "img" and "theme" folders on the server where the OpenLayers-ms60.js file lives: http://mapserver.org/lib/
>>>>>>>> If I test the CGI with MODE=browse&TEMPLATE=openlayers, my map will always appear, I can zoom/pan, but the OpenLayers control images (zoom,
>>>>>>>> pan) are broken. Firebug is looking for them at something like 127.0.0.1/cgi-bin/img/north-mini.png and 127.0.0.1/cgi-bin/theme/default/style.css
>>>>>>>> Looking at http://mapserver.org/lib/ I see that the OL file was modified on April 15th...I wonder if this has to do with the server changes, and possibly those img/style folders were not moved?
>>>>>>>> Or put another way: can anyone else see the zoom/pan images now when trying mode=browse&template=openlayers ??
>>>>>>>> Thanks all!
>>>>>>>> -jeff
>>>>>>>> PS. it would be odd if I am the first person to notice this in 2 months!!!
>>>>>>>> _______________________________________________
>>>>>> mapserver-dev mailing list
>>>>>> mapserver-dev at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>>>> Jeff McKenna
>>>> MapServer Consulting and Training Services
>>>> http://www.gatewaygeomatics.com/
>> Jeff McKenna
Jeff McKenna
