[mapserver-dev] missing files using built-in OpenLayers template
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Jun 16 06:26:02 PDT 2014
I wonder if all this wonkiness is because we name our build something
other than OpenLayers.js
-jeff
On 2014-06-16, 10:19 AM, Jeff McKenna wrote:
> I had already changed the ImgPath, and I clear my cache constantly..no
> this ImgPath change is in fact needed in our case for some reason. (Now
> i'm battling the missing style path also). Looking...
> -jeff
> On 2014-06-16, 10:16 AM, thomas bonfort wrote:
>> hmm, I was wondering why that wasn't needed beforehand. Actually the
>> viewer works correctly with the lib files you added this morning, just
>> make sure your browser cache is purged.
>> thomas
>> On 16 June 2014 15:06, Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
>>> Oh interesting, I've never had to set that with single file builds..will
>>> try now thanks!
>>> -jeff
>>> On 2014-06-16, 10:01 AM, thomas bonfort wrote:
>>>> OpenLayers.ImgPath should probably be set to
>>>> "http://www.mapserver.org/lib/" in our generated JS.
>>>> On 16 June 2014 14:58, Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
>>>>> Hi THomas,
>>>>> Yes in fact I placed those files there this morning, the 'img' and
>>>>> 'theme' folders were missing.
>>>>> Correct, this single file build does not seem to be properly looking for
>>>>> those files, it should be looking right in the same folder.
>>>>> -jeff
>>>>> On 2014-06-16, 9:55 AM, thomas bonfort wrote:
>>>>>> Jeff,
>>>>>> The files are present now (c.f.
>>>>>> http://www.mapserver.org/lib/theme/default/) however there's something
>>>>>> wrong with our generated javascript as it's requesting the theme files
>>>>>> from http://server/cgi-bin/theme/default/style.css instead of
>>>>>> www.mapserver.org/lib/...
>>>>>> On 16 June 2014 14:27, Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
>>>>>>> Still no luck, I would have thought that this OpenLayers single build
>>>>>>> would look in the same directory for the img and theme folders. Anyone
>>>>>>> have any ideas?
>>>>>>> -jeff
>>>>>>> On 2014-06-16, 9:09 AM, Jeff McKenna wrote:
>>>>>>>> Oh ok great, thanks for confirming this Lars, I thought I was going crazy :)
>>>>>>>> I have no idea how the website and github are linked now, but I just
>>>>>>>> poked around the ProjectsVM and found that js file, so I copied the img
>>>>>>>> and theme folders there: http://www.mapserver.org/lib/ ...but still no
>>>>>>>> luck. Will keep looking.
>>>>>>>> -jeff
>>>>>>>> On 2014-06-16, 5:47 AM, Schylberg Lars wrote:
>>>>>>>>> You are right Jeff,
>>>>>>>>> The openlayers script was missing in April and I asked that it would be put back.
>>>>>>>>> It was recoverd but unfortunally the small images was not put back.
>>>>>>>>> I started to use a local copy at the same time so I forgot to mention that as well.
>>>>>>>>> /Lars S.
>>>>>>>>> -----Original Message-----
>>>>>>>>> From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Jeff McKenna
>>>>>>>>> Sent: den 16 juni 2014 00:32
>>>>>>>>> To: 'MapServer Dev Mailing List'
>>>>>>>>> Subject: [mapserver-dev] missing files using built-in OpenLayers template
>>>>>>>>> Hello all,
>>>>>>>>> I have hit a wall, and I am hoping someone can confirm my suspicions.
>>>>>>>>> When using the built-in OpenLayers template (http://mapserver.org/development/rfc/ms-rfc-63.html), I believe there are some missing "img" and "theme" folders on the server where the OpenLayers-ms60.js file lives: http://mapserver.org/lib/
>>>>>>>>> If I test the CGI with MODE=browse&TEMPLATE=openlayers, my map will always appear, I can zoom/pan, but the OpenLayers control images (zoom,
>>>>>>>>> pan) are broken. Firebug is looking for them at something like 127.0.0.1/cgi-bin/img/north-mini.png and 127.0.0.1/cgi-bin/theme/default/style.css
>>>>>>>>> Looking at http://mapserver.org/lib/ I see that the OL file was modified on April 15th...I wonder if this has to do with the server changes, and possibly those img/style folders were not moved?
>>>>>>>>> Or put another way: can anyone else see the zoom/pan images now when trying mode=browse&template=openlayers ??
>>>>>>>>> Thanks all!
>>>>>>>>> -jeff
>>>>>>>>> PS. it would be odd if I am the first person to notice this in 2 months!!!
>>>>>>>>> _______________________________________________
>>>>>>> mapserver-dev mailing list
>>>>>>> mapserver-dev at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>>>>> Jeff McKenna
>>>>> MapServer Consulting and Training Services
>>>>> http://www.gatewaygeomatics.com/
>>> Jeff McKenna
Jeff McKenna
