[mapserver-dev] Improving SLD generated by MS: need small help :)
Yves Jacolin
yves.jacolin at camptocamp.com
Sat May 10 02:40:19 PDT 2014
Hello,
I am testing MapServer generating SLD file. I then import them into
GeoServer and check the difference. I try to change the source code of
MapServer (add propertyName for label, support outline(width|color),
support some vendor parameter, better support for label with halo, support
expression list).
At this moment I am improving my seconde PR thanks to Thomas comment [1]
but I am stuck with a small issue:
I have this kind of mapfile:
STYLE
WIDTH 0.5
OUTLINEWIDTH 2
OUTLINECOLOR 0 0 0
#COLOR "#aaaaaa"
END
The SLD generated for the WIDTH/COLOR part is:
<se:Stroke>
<se:SvgParameter name="stroke">#</se:SvgParameter>
<se:SvgParameter name="stroke-width">0.50</se:SvgParameter>
</se:Stroke>
And my source code is:
if ((psStyle->outlinewidth > 0 && &psStyle->outlinecolor) &&
(psStyle->width >= 0 && &psStyle->color))
This test is not working properly as psStyle->color exists but doesn't
contains anything but '#' symbol.
Any idea how to test if a color parameter has been defined in a mapfile?
Thanks,
Y.
[1] https://github.com/mapserver/mapserver/pull/4922
Responsable Formation et Support
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel (France) : +33 4 79 26 57 98
Tel (Suisse) : 021 619 10 43
Mob. : +33 6 18 75 42 21
Fax : 04 79 70 15 81
Mail : yves.jacolin at camptocamp.com
http://www.camptocamp.com
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20140510/f5308361/attachment.html>
