[mapserver-dev] Improving SLD generated by MS: need small help :)
Yves Jacolin yves.jacolin at camptocamp.com
Sat May 10 03:20:18 PDT 2014
of course it was too easy:
if (psStyle->color.red != -1 && psStyle->color.green != -1 &&
psStyle->color.blue != -1)
I will update my PR :)
Y.
2014-05-10 11:40 GMT+02:00 Yves Jacolin <yves.jacolin at camptocamp.com>:
> Hello,
> I am testing MapServer generating SLD file. I then import them into
> GeoServer and check the difference. I try to change the source code of
> MapServer (add propertyName for label, support outline(width|color),
> support some vendor parameter, better support for label with halo, support
> expression list).
> At this moment I am improving my seconde PR thanks to Thomas comment [1]
> but I am stuck with a small issue:
> I have this kind of mapfile:
>         STYLE
>             WIDTH 0.5
>             OUTLINEWIDTH 2
>             OUTLINECOLOR 0 0 0
>             #COLOR "#aaaaaa"
>         END
> The SLD generated for the WIDTH/COLOR part is:
> <se:Stroke>
>   <se:SvgParameter name="stroke">#</se:SvgParameter>
>   <se:SvgParameter name="stroke-width">0.50</se:SvgParameter>
> </se:Stroke>
> And my source code is:
> if ((psStyle->outlinewidth > 0 && &psStyle->outlinecolor) &&
> (psStyle->width >= 0 && &psStyle->color))
> This test is not working properly as psStyle->color exists but doesn't
> contains anything but '#' symbol.
> Any idea how to test if a color parameter has been defined in a mapfile?
> Thanks,
> Y.
> [1] https://github.com/mapserver/mapserver/pull/4922
> Responsable Formation et Support
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel (France) : +33 4 79 26 57 98
> Tel (Suisse) : 021 619 10 43
> Mob. : +33 6 18 75 42 21
> Fax : 04 79 70 15 81
> Mail : yves.jacolin at camptocamp.com
> http://www.camptocamp.com
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20140510/21924904/attachment.html>
