[mapserver-dev] Improving SLD generated by MS: need small help :)
thomas bonfort
thomas.bonfort at gmail.com
Sat May 10 03:21:22 PDT 2014
there's a MS_VALID_COLOR (iirc or something similar) macro defined for that
thomas
On 10 May 2014 12:20, Yves Jacolin <yves.jacolin at camptocamp.com> wrote:
> of course it was too easy:
> if (psStyle->color.red != -1 && psStyle->color.green != -1 &&
> psStyle->color.blue != -1)
> I will update my PR :)
> Y.
> 2014-05-10 11:40 GMT+02:00 Yves Jacolin <yves.jacolin at camptocamp.com>:
>> Hello,
>> I am testing MapServer generating SLD file. I then import them into
>> GeoServer and check the difference. I try to change the source code of
>> MapServer (add propertyName for label, support outline(width|color), support
>> some vendor parameter, better support for label with halo, support
>> expression list).
>> At this moment I am improving my seconde PR thanks to Thomas comment [1]
>> but I am stuck with a small issue:
>> I have this kind of mapfile:
>> STYLE
>> WIDTH 0.5
>> OUTLINEWIDTH 2
>> OUTLINECOLOR 0 0 0
>> #COLOR "#aaaaaa"
>> END
>> The SLD generated for the WIDTH/COLOR part is:
>> <se:Stroke>
>> <se:SvgParameter name="stroke">#</se:SvgParameter>
>> <se:SvgParameter name="stroke-width">0.50</se:SvgParameter>
>> </se:Stroke>
>> And my source code is:
>> if ((psStyle->outlinewidth > 0 && &psStyle->outlinecolor) &&
>> (psStyle->width >= 0 && &psStyle->color))
>> This test is not working properly as psStyle->color exists but doesn't
>> contains anything but '#' symbol.
>> Any idea how to test if a color parameter has been defined in a mapfile?
>> Thanks,
>> Y.
>> [1] https://github.com/mapserver/mapserver/pull/4922
>> Responsable Formation et Support
>> Camptocamp France SAS
>> Savoie Technolac, BP 352
>> 73377 Le Bourget du Lac, Cedex
>> Tel (France) : +33 4 79 26 57 98
>> Tel (Suisse) : 021 619 10 43
>> Mob. : +33 6 18 75 42 21
>> Fax : 04 79 70 15 81
>> Mail : yves.jacolin at camptocamp.com
>> http://www.camptocamp.com
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
