[mapserver-dev] Improving SLD generated by MS: need small help :)
Yves Jacolin
yves.jacolin at camptocamp.com
Sat May 10 03:39:55 PDT 2014
Thanks Thomas, even simplier now :)
Y.
2014-05-10 12:21 GMT+02:00 thomas bonfort <thomas.bonfort at gmail.com>:
> there's a MS_VALID_COLOR (iirc or something similar) macro defined for that
> thomas
> On 10 May 2014 12:20, Yves Jacolin <yves.jacolin at camptocamp.com> wrote:
> > of course it was too easy:
> > if (psStyle->color.red != -1 && psStyle->color.green != -1 &&
> > psStyle->color.blue != -1)
> > I will update my PR :)
> > Y.
> > 2014-05-10 11:40 GMT+02:00 Yves Jacolin <yves.jacolin at camptocamp.com>:
> >> Hello,
> >> I am testing MapServer generating SLD file. I then import them into
> >> GeoServer and check the difference. I try to change the source code of
> >> MapServer (add propertyName for label, support outline(width|color),
> support
> >> some vendor parameter, better support for label with halo, support
> >> expression list).
> >> At this moment I am improving my seconde PR thanks to Thomas comment [1]
> >> but I am stuck with a small issue:
> >> I have this kind of mapfile:
> >> STYLE
> >> WIDTH 0.5
> >> OUTLINEWIDTH 2
> >> OUTLINECOLOR 0 0 0
> >> #COLOR "#aaaaaa"
> >> END
> >> The SLD generated for the WIDTH/COLOR part is:
> >> <se:Stroke>
> >> <se:SvgParameter name="stroke">#</se:SvgParameter>
> >> <se:SvgParameter name="stroke-width">0.50</se:SvgParameter>
> >> </se:Stroke>
> >> And my source code is:
> >> if ((psStyle->outlinewidth > 0 && &psStyle->outlinecolor) &&
> >> (psStyle->width >= 0 && &psStyle->color))
> >> This test is not working properly as psStyle->color exists but doesn't
> >> contains anything but '#' symbol.
> >> Any idea how to test if a color parameter has been defined in a mapfile?
> >> Thanks,
> >> Y.
> >> [1] https://github.com/mapserver/mapserver/pull/4922
> >> Responsable Formation et Support
> >> Camptocamp France SAS
> >> Savoie Technolac, BP 352
> >> 73377 Le Bourget du Lac, Cedex
> >> Tel (France) : +33 4 79 26 57 98
> >> Tel (Suisse) : 021 619 10 43
> >> Mob. : +33 6 18 75 42 21
> >> Fax : 04 79 70 15 81
> >> Mail : yves.jacolin at camptocamp.com
> >> http://www.camptocamp.com
> > mapserver-dev mailing list
> > mapserver-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20140510/e0d9e09a/attachment.html>
