[mapserver-dev] OGC Certification Badge
Rahkonen Jukka (Tike)
jukka.rahkonen at mmmtike.fi
Tue Nov 11 14:28:50 PST 2014
Hi Stephan,
I do believe that recent versions are as compliant but if we would decide to advertise to our clients that we are doing good job with a certified server we would have to use the same version that received the badge. But I do not believe that we will do it if clients are not requesting it because actually it could make it harder for us to upgrade. But such requests may arise.
Do you know if they are delivering INSPIRE badges somewhere?
-Jukka Rahkonen-
________________________________________
Stephan Meißl wrote:
Hi Jukka,
of course more recent versions of MapServer also fully support WCS 2.0.
I just didn't have the time yet to setup and maintain an endpoint, run
the OGC tests against it, and run through the OGC processes to get the
official certification and badge.
cu
Stephan
On 11/07/2014 11:37 AM, Rahkonen Jukka (Tike) wrote:
> Hi,
> Is the badge valid only for 6.2? It might be good for us to be able to tell that we use a certified server for WCS but I would not like so much to downgrade and run two different versions of Mapserver.
> -Jukka Rahkonen-
>> Hi all,
>> do we want to add this nice OGC certification badge [1] to our documentation
>> or homepage? Which would be the most appropriate place?
>> cu
>> Stephan
>> [1]
>> https://portal.opengeospatial.org/public_ogc/compliance/srv_ogc_compliance
>> _badge.php?id=102&pid=1083
mapserver-dev mailing list
mapserver-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
