[mapserver-dev] Broken tests should be suppressed
Tamas Szekeres
szekerest at gmail.com
Fri Nov 28 12:07:16 PST 2014
Hi Devs,
Is that possible to disable all those failing tests from the test suite
until the corresponding issues are getting fixed? Not sure if anyone is
working on that actively, but the travis-ci test suite is broken for quite
a long time.
Best regards,
Tamas
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20141128/c011d693/attachment.html>
