[mapserver-dev] Broken tests should be suppressed
thomas bonfort
thomas.bonfort at gmail.com
Fri Nov 28 13:31:17 PST 2014
Tamas,
I don't think it's a good idea to disable those tests, we should
instead work on fixing the underlying issues. And then release a beta
for 7.0...
regards,
thomas
On 28 November 2014 at 21:07, Tamas Szekeres <szekerest at gmail.com> wrote:
> Hi Devs,
> Is that possible to disable all those failing tests from the test suite
> until the corresponding issues are getting fixed? Not sure if anyone is
> working on that actively, but the travis-ci test suite is broken for quite a
> long time.
> Best regards,
> Tamas
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
