[mapserver-dev] Documentation for occasional contributors
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Oct 15 06:13:11 PDT 2014
On 2014-10-15 6:42 AM, Peter Hopfgartner wrote:
> I'd say, the moment the developers documentation could be improved in
> some points.
> As a first point, I do have problems on how to run the test suite with
> my changes. Could the information in
> http://www.mapserver.org/development/tests/autotest.html be updated?
> Then, a page describing the workflow with git, much like
> http://docs.geoserver.org/latest/en/developer/source.html help.
> Thanks and best regards,
> Peter
At first I thought you were asking for exact git/workflow for how to
contribute to documentation, which we have :) Here it is for the record
anyway: http://www.mapserver.org/development/documentation.html#background
Maybe as you travel down your dev path you can also enhance the docs
that you are using.
-jeff
