[mapserver-dev] RE : RE: Appveyor Windows continuous integration
Even Rouault even.rouault at spatialys.com
Wed Aug 12 09:13:14 PDT 2015
Le lundi 10 août 2015 22:13:11, Even Rouault a écrit :
> Le lundi 10 août 2015 20:51:32, Lime, Steve D (MNIT) a écrit :
> > ‘Today’ means Monday I guess. I created an MapServer account and added
> > Even as a collaborator/administrator and added the mapserver/owner and
> > developers github teams as administrators and users respectively.
> > Hopefully that was correct.
> Steve,
> For some reason, I can't do any modification to the appveyor mapserver
> project, even once logged in.
> I've pushed appveyor.yml to mapserver master. It should be hopefuly
> relatively easy for you to enable mapserver builds now.
This is now in place and the first build ran:
https://ci.appveyor.com/project/MapServer/mapserver/build/1.0.1
appveyor.yml is currently only in master, so only master commits will be
tested. It could be copied to branch-7-0 as well if needed.
> Even
> > Steve
> > From: mapserver-dev-bounces at lists.osgeo.org
> > [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Lime, Steve D
> > (MNIT) Sent: Friday, August 07, 2015 7:55 AM
> > To: Even Rouault <even.rouault at spatialys.com>; mapserver-dev
> > <mapserver-dev at lists.osgeo.org> Subject: Re: [mapserver-dev] RE : RE:
> > I’ll do that today and get back with you.
> > From: Even Rouault [mailto:even.rouault at spatialys.com]
> > Sent: Thursday, August 06, 2015 5:13 PM
> > To: Lime, Steve D (MNIT)
> > <Steve.Lime at state.mn.us<mailto:Steve.Lime at state.mn.us>>; mapserver-dev
> > <mapserver-dev at lists.osgeo.org<mailto:mapserver-dev at lists.osgeo.org>>
> > Subject: RE : RE: [mapserver-dev] Appveyor Windows continuous integration
> > Steve,
> > the best would be then that you create the account since it will need an
> > e mail for activation and in case of password forgetting. You can then
> > add my github account as additional administrator.
> > Even
> > Spatialys - Geospatial professional services
> > http://www.spatialys.com
> > -------- Message d'origine --------
> > De : "Lime, Steve D (MNIT)"
> > <Steve.Lime at state.mn.us<mailto:Steve.Lime at state.mn.us>> Date :07/08/2015
> > 00:00 (GMT+01:00)
> > À : Even Rouault
> > <even.rouault at spatialys.com<mailto:even.rouault at spatialys.com>>,
> > mapserver-dev
> > <mapserver-dev at lists.osgeo.org<mailto:mapserver-dev at lists.osgeo.org>> Cc
> > : Objet : RE: [mapserver-dev] Appveyor Windows continuous integration
> > Hi Even: Thanks for taking this on. Seems useful I since most devs have
> > zero way to test changes in the context of Windows. Making it work with a
> > MapServer-specific account against master sounds like the way to go
> > rather than burdening your account. I'd be happy being the
> > username/password custodian if need be.
> > Steve
> > -----Original Message-----
> > From:
> > mapserver-dev-bounces at lists.osgeo.org<mailto:mapserver-dev-bounces at lists.
> > o sgeo.org> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of
> > Even Rouault Sent: Thursday, August 06, 2015 7:34 AM
> > To: mapserver-dev
> > Subject: [mapserver-dev] Appveyor Windows continuous integration
> > Hi,
> > I've experimented a Appveyor Windows continuous integration setup in my
> > fork : https://github.com/rouault/mapserver/blob/appveyor/appveyor.yml
> > And finally managed to get a successful build:
> > https://ci.appveyor.com/project/rouault/mapserver/build/1.0.33
> > It does 32 and 64 bit builds, with Visual Studio 12 2013 (other versions
> > could be added to the matrix).
> > The current options are :
> > -- * Summary of configured options for this build
> > --  * Mandatory components
> > --   * png: C:\projects\mapserver\sdk\release-1800-x64\lib\libpng.lib
> > --   * jpeg: C:/projects/mapserver/sdk/release-1800-x64/lib/libjpeg.lib
> > --   * freetype: C:/projects/mapserver/sdk/release-1800-
> > x64/lib/freetype2411.lib
> > --  * Optional components
> > --   * GDAL: C:/projects/mapserver/sdk/release-1800-x64/lib/gdal_i.lib
> > --   * OGR: C:/projects/mapserver/sdk/release-1800-x64/lib/gdal_i.lib
> > --   * GIF: C:/projects/mapserver/sdk/release-1800-x64/lib/giflib.lib
> > --   * MYSQL: disabled
> > --   * FRIBIDI:
> > C:/projects/mapserver/sdk/release-1800-x64/lib/fribidi.lib --   *
> > HARFBUZZ:
> > C:/projects/mapserver/sdk/release-1800-x64/lib/harfbuzz.lib --   * GIF:
> > C:/projects/mapserver/sdk/release-1800-x64/lib/giflib.lib --   * CAIRO:
> > C:/projects/mapserver/sdk/release-1800-x64/lib/cairo.lib --   * SVGCAIRO:
> > C:/projects/mapserver/sdk/release-1800-x64/lib/libsvg- cairo.lib
> > --   * RSVG: disabled
> > --   * CURL:
> > C:/projects/mapserver/sdk/release-1800-x64/lib/libcurl_imp.lib --   *
> > PROJ: C:/projects/mapserver/sdk/release-1800-x64/lib/proj_i.lib --   *
> > PIXMAN: disabled
> > --   * LIBXML2:
> > C:/projects/mapserver/sdk/release-1800-x64/lib/libxml2.lib --   *
> > POSTGIS: C:/projects/mapserver/sdk/release-1800-x64/lib/libpqdll.lib --
> >  * GEOS: C:/projects/mapserver/sdk/release-1800-x64/lib/geos_c.lib --
> > * FastCGI: C:/projects/mapserver/sdk/release-1800-x64/lib/libfcgi.lib --
> >   * Oracle Spatial: disabled
> > --   * Exempi XMP: disabled
> > --  * Optional features
> > --   * WMS SERVER: ENABLED
> > --   * WFS SERVER: ENABLED
> > --   * WCS SERVER: ENABLED
> > --   * SOS SERVER: ENABLED
> > --   * WMS CLIENT: ENABLED
> > --   * WFS CLIENT: ENABLED
> > --   * ICONV: ENABLED
> > --   * Thread-safety support: ENABLED
> > --   * KML output: ENABLED
> > --   * Z+M point coordinate support: ENABLED
> > --   * XML Mapfile support: disabled
> > --  * Mapscripts
> > --   * Python: ENABLED
> > --   * PHP: disabled
> > --   * PERL: disabled
> > --   * RUBY: disabled
> > --   * JAVA: disabled
> > --   * C#: disabled
> > --   * V8 Javascript: disabled
> > --   * Apache Module (Experimental): disabled
> > So pretty much all external libs + python. No tests are run.
> > This relies heavily on Tamas' SDKs to provide all the required
> > dependencies. But I had some hard time figuring out a few cmake options.
> > I couldn't find any online page with a cmake Windows setup. The weirdest
> > oddity I had to fight is that I had to do "copy libpng.lib
> > libpng.lib.lib" to be able to link. iconv was a bit particular too since
> > you have to specify ICONV_DLL unlike other libraries. And for curl
> > linking I add to specify -
> > DMS_EXTERNAL_LIBS=wsock32.lib
> > Is there interest in migrating this to master ? My experience is that
> > Appveyor response time is rather dependant on the hour of the day. It can
> > fire jobs a few seconds after push at morning/early afternoon European
> > time, but I found that later in the day when North Americans wake up,
> > builds can be queued for minutes or hours. At least, this seems true for
> > free accounts like mine.
> > The appveyor account used is mine currently. I could update it to build
> > from the official mapserver github repo instead of my fork, and I believe
> > that should work, even for pull requests.
> > Perhaps it would be best to have a appveyor "mapserver" account, but
> > there's no easy way with Appveyor to create a Appveyor account linked to
> > a github organization account like mapserver (contrary to Travis I
> > believe). I found that one can create manually a appveyor mapserver
> > account, with independant login&password identification, and then add
> > github accounts of individuals as administrators. I can try that if
> > that's OK.
> > Best regards,
> > Even
> > mapserver-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
