[mapserver-dev] PHP Mapscript - setting PostLabelCache stops text displaying
Ian Walberg
ian.walberg at airborne.aero
Mon Aug 17 16:14:46 PDT 2015
Folks,
Using PHP Mapscript it appears that when PostLabelCache is set to '1' for a label layer this causes the label text not to display.
With a map file this works as expected.
Looking in the mapscript/php source directory there are mutiple '#ifdef disabled' around the labelcache functions.
Is anyone aware of this? Should I raise an issue?
Thanks, Ian
