[mapserver-dev] PHP Mapscript - setting PostLabelCache stops text displaying
Ian Walberg
ian.walberg at airborne.aero
Tue Aug 18 11:48:02 PDT 2015
I have raised this as an issue https://github.com/mapserver/mapserver/issues/5142
-----Original Message-----
From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Ian Walberg
Sent: Monday, August 17, 2015 4:15 PM
To: mapserver-dev at lists.osgeo.org; mapserver-users at lists.osgeo.org
Subject: [mapserver-dev] PHP Mapscript - setting PostLabelCache stops text displaying
Folks,
Using PHP Mapscript it appears that when PostLabelCache is set to '1' for a label layer this causes the label text not to display.
With a map file this works as expected.
Looking in the mapscript/php source directory there are mutiple '#ifdef disabled' around the labelcache functions.
Is anyone aware of this? Should I raise an issue?
Thanks, Ian
mapserver-dev mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
