[mapserver-dev] MS 7.0 and WFS with MSSQL backend broken
Tamas Szekeres
szekerest at gmail.com
Wed Aug 19 10:34:57 PDT 2015
Hi Seth,
Could you provide your SQL table definition in the database and the LAYER
definition in the map file?
Thanks,
Tamas
2015-08-19 10:43 GMT+02:00 geographika <geographika at gmail.com>:
> Hi all,
> I have updated my system to using MS7 (with a dev build from
> gisinternals.com).
> WMS layers are all working fine but all WFS layers are broken. Any
> GetFeature request returns the following:
> Query error. msMSSQL2008LayerGetItems: tried to find the geometry
> column in the results from the database, but couldnt find it. Is it
> miss-capitialized? 'GEOM'
> My layer configurations have not changed (and work fine in 6.4), and
> looking at SQL Profiler the initial query to get the column names runs
> successfully and returns a GEOM field.
> I've looked at changes to
> https://github.com/mapserver/mapserver/blob/branch-7-0/mapmssql2008.c and
> can't see what would have changed to cause this error.
> There appears to be nothing related to this in the
> http://mapserver.org/MIGRATION_GUIDE.html
> Does anyone have any idea what may have changed, or if the DATA clauses
> need modifying for MS7?
> If not I will try and debug further.
> Regards,
> Seth
> web: http://geographika.co.uk
> twitter: @geographika
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20150819/7bbd0738/attachment.html>
