[mapserver-dev] [EXTERNAL] Re: Motion: Retire SDE Support for MapServer 7.0
Stephen Woodbridge woodbri at swoodbridge.com
Wed Feb 11 06:40:11 PST 2015
I'll echo Daniel's thoughts on this. +0 on removing it. I might be a
little closer to the +1  given that we can not test it either, because
that implies it is an issue waiting to happen and it makes some sense to
push users to the ogr solution.
-Steve W
On 2/11/2015 9:35 AM, Smith, Michael ERDC-RDE-CRREL-NH wrote:
> I'm +1 on this.
> Mike
> On 2/11/15, 8:50 AM, "Daniel Morissette" <dmorissette at mapgears.com> wrote:
>> I have no strong position on this one, but since the code of this driver
>> is unmaintained and a suitable alternative exists (through OGR), then
>> I'd be at least +0 for removing it.
>> Daniel
>> On 2015-02-10 4:30 PM, Howard Butler wrote:
>>> All,
>>> As the former maintainer and current non-maintainer of the SDE
>>> MapServer driver, I would like to motion that we we retire it from
>>> MapServer for the upcoming release. There are three reasons to consider
>>> removal at this time:
>>> 1) Availability of the ArcSDE SDK is extremely low (can you even get
>>> ESRI to give it to you?)
>>> 2) Viability of direct-database query from PostGIS, Oracle, and SQL
>>> Server have obsoleted SDE
>>> 3) No current MapServer developers have the ability to test any code
>>> changes to the SDE driver.
>>> Howard
>>> mapserver-dev mailing list
>>> mapserver-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>> Daniel Morissette
>> T: +1 418-696-5056 #201
>> http://www.mapgears.com/
>> Provider of Professional MapServer Support since 2000
