[mapserver-dev] [EXTERNAL] Re: Motion: Retire SDE Support for MapServer 7.0
Even Rouault
even.rouault at spatialys.com
Wed Feb 11 06:54:53 PST 2015
Le mercredi 11 février 2015 15:40:11, Stephen Woodbridge a écrit :
> I'll echo Daniel's thoughts on this. +0 on removing it. I might be a
> little closer to the +1 given that we can not test it either, because
> that implies it is an issue waiting to happen and it makes some sense to
> push users to the ogr solution.
Note: all arguments given by Howard regarding the MapServer SDE plugin apply
as well to the OGR SDE one... Last (non automated) commit in it was 2 years
ago.
> -Steve W
> On 2/11/2015 9:35 AM, Smith, Michael ERDC-RDE-CRREL-NH wrote:
> > I'm +1 on this.
> > Mike
> > On 2/11/15, 8:50 AM, "Daniel Morissette" <dmorissette at mapgears.com> wrote:
> >> I have no strong position on this one, but since the code of this driver
> >> is unmaintained and a suitable alternative exists (through OGR), then
> >> I'd be at least +0 for removing it.
> >> Daniel
> >> On 2015-02-10 4:30 PM, Howard Butler wrote:
> >>> All,
> >>> As the former maintainer and current non-maintainer of the SDE
> >>> MapServer driver, I would like to motion that we we retire it from
> >>> MapServer for the upcoming release. There are three reasons to consider
> >>> removal at this time:
> >>> 1) Availability of the ArcSDE SDK is extremely low (can you even get
> >>> ESRI to give it to you?)
> >>> 2) Viability of direct-database query from PostGIS, Oracle, and SQL
> >>> Server have obsoleted SDE
> >>> 3) No current MapServer developers have the ability to test any code
> >>> changes to the SDE driver.
> >>> Howard
> >>> _______________________________________________
> >>> mapserver-dev mailing list
> >>> mapserver-dev at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
> >> Daniel Morissette
> >> T: +1 418-696-5056 #201
> >> http://www.mapgears.com/
> >> Provider of Professional MapServer Support since 2000
http://www.spatialys.com
