[mapserver-dev] [EXTERNAL] Re: Motion: Retire SDE Support for MapServer 7.0
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Feb 11 07:40:08 PST 2015
Even, Thank you for the additional info in the SDE options.
We might want to put out an inquiry to the user lists to see with there
are people using these and what version of software they are using it
against. In general if the community is not using/supporting a feature
then I see no reason to continue carrying it if we (the community) can
not verify that it works and is useful. That said, I think we should
give due notification that we are planning to drop it and why.
-Steve W
On 2/11/2015 9:54 AM, Even Rouault wrote:
> Le mercredi 11 février 2015 15:40:11, Stephen Woodbridge a écrit :
>> I'll echo Daniel's thoughts on this. +0 on removing it. I might be a
>> little closer to the +1 given that we can not test it either, because
>> that implies it is an issue waiting to happen and it makes some sense to
>> push users to the ogr solution.
> Note: all arguments given by Howard regarding the MapServer SDE plugin apply
> as well to the OGR SDE one... Last (non automated) commit in it was 2 years
> ago.
>> -Steve W
>> On 2/11/2015 9:35 AM, Smith, Michael ERDC-RDE-CRREL-NH wrote:
>>> I'm +1 on this.
>>> Mike
>>> On 2/11/15, 8:50 AM, "Daniel Morissette" <dmorissette at mapgears.com> wrote:
>>>> I have no strong position on this one, but since the code of this driver
>>>> is unmaintained and a suitable alternative exists (through OGR), then
>>>> I'd be at least +0 for removing it.
>>>> Daniel
>>>> On 2015-02-10 4:30 PM, Howard Butler wrote:
>>>>> All,
>>>>> As the former maintainer and current non-maintainer of the SDE
>>>>> MapServer driver, I would like to motion that we we retire it from
>>>>> MapServer for the upcoming release. There are three reasons to consider
>>>>> removal at this time:
>>>>> 1) Availability of the ArcSDE SDK is extremely low (can you even get
>>>>> ESRI to give it to you?)
>>>>> 2) Viability of direct-database query from PostGIS, Oracle, and SQL
>>>>> Server have obsoleted SDE
>>>>> 3) No current MapServer developers have the ability to test any code
>>>>> changes to the SDE driver.
>>>>> Howard
>>>>> _______________________________________________
>>>>> mapserver-dev mailing list
>>>>> mapserver-dev at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>>>> Daniel Morissette
>>>> T: +1 418-696-5056 #201
>>>> http://www.mapgears.com/
>>>> Provider of Professional MapServer Support since 2000
