[mapserver-dev] Configuring TinyOWS x1.1.1
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Jul 28 12:24:17 PDT 2015
Hello TinyOWS team,
I've compiled the latest TinyOWS release, 1.1.1, on Windows, but I am
having trouble testing it (getting it to successfully execute a WFS-T
transaction). Here is more information:
Environment
- Windows
- compiled against: PostgreSQL 9.4.4
libxml2-2.9.2
libiconv 1.11.1
regex 0.12
fcgi 2.4.0
Testing
- Used tinyows.js and tinyows.html from
http://www.mapserver.org/tinyows/openlayershowto.html
- pointing to OpenLayers 2.13.1 instance (assumed OL3 would have no
chance to work with the older testing steps)
config.xml
<tinyows online_resource="http://127.0.0.1:8081/cgi-bin/tinyows.exe"
schema_dir="/usr/local/share/tinyows/schema/">
<pg host="localhost" user="postgres" password="postgres"
dbname="tinyows" port="5437"/>
<metadata name="TinyOWS Server"
title="TinyOWS Server - WFS-T Frida Service" />
<contact name="TinyOWS Server"
site="http://www.tinyows.org/"
email="tinyows-users at lists.maptools.org" />
<layer retrievable="1"
writable="1"
ns_prefix="tows"
ns_uri="http://www.tinyows.org/"
name="frida"
title="Frida Parks" />
</tinyows>
tinyows.exe --check
C:\ms4w>tinyows --check
TinyOWS version: 1.1.0
FCGI support: Yes
Config File Path: C:/ms4w/apps/tinyows/config.xml (TinyOWS XML)
PostGIS Version: 2.1.7
PostGIS dsn: host=localhost user=postgres password=postgres
dbname=tinyows port=5437
Output Encoding: UTF-8
Database Encoding: UTF8
Schema dir: /usr/local/share/tinyows/schema/
Display bbox: Yes
Estimated extent: No
Check schema: Yes
Check valid geoms: Yes
Available layers:
- public.frida (31467) -> tows:frida [RW]
Error Message
- after drawing a polygon, then clicking the 'save' button, the
following message is displayed:
"An error occured while operating the transaction"
Request
If I check into what is the actual request being sent:
<wfs:Transaction xmlns:wfs="http://www.opengis.net/wfs" service="WFS"
version="1.1.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/wfs
http://schemas.opengis.net/wfs/1.1.0/wfs.xsd http://www.tinyows.org/
http://127.0.0.1:8081/cgi-bin/tinyows.exe?service=wfs&request=DescribeFeatureType&version=1.1.0&typename=tows:frida"><wfs:Insert><feature:frida
xmlns:feature="http://www.tinyows.org/"><feature:geom><gml:MultiSurface
xmlns:gml="http://www.opengis.net/gml"
srsName="EPSG:31467"><gml:surfaceMember><gml:Polygon><gml:exterior><gml:LinearRing><gml:posList>3441587.5
5798066.125 3443267.5 5797850.125 3442043.5 5797202.125 3441587.5
5798066.125</gml:posList></gml:LinearRing></gml:exterior></gml:Polygon></gml:surfaceMember></gml:MultiSurface></feature:geom></feature:frida></wfs:Insert></wfs:Transaction>
Response
If I check into the actual response returned:
<?xml version='1.0' encoding='UTF-8'?>
<ows:ExceptionReport
xmlns='http://www.opengis.net/ows'
xmlns:ows='http://www.opengis.net/ows'
xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'
xsi:schemaLocation='http://www.opengis.net/ows
http://schemas.opengis.net/ows/1.0.0/owsExceptionReport.xsd'
version='1.1.0' language='en'>
<ows:Exception exceptionCode='InvalidParameterValue' locator='request'>
<ows:ExceptionText>XML request isn't valid</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
Other notes
- Could it be the schema dir? Where should that be set to, if so?
Let me know if anyone has any ideas for this. Thanks,
-jeff
