[mapserver-dev] Configuring TinyOWS x1.1.1
Oliver Courtin olivier.courtin at oslandia.com
Wed Jul 29 09:33:32 PDT 2015
Le 28 juil. 2015 à 21:24, Jeff McKenna a écrit :
Hi Jeff,
>  <ows:ExceptionText>XML request isn't valid</ows:ExceptionText>
What happen if you set the 'check_schema' option to 0 ?
(in tinyows config file)
> - Could it be the schema dir?  Where should that be set to, if so?
In command line, launch a tinyows.exe -h,
there's a line in the output related to "Schema dir" path
HTH,
O.
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20150729/4b738379/attachment.html>
