[mapserver-dev] Upgrading Sphinx/Docs to 1.3.1
thomas bonfort thomas.bonfort at gmail.com
Tue May 5 23:32:44 PDT 2015
Jeff,
the docs are built on travis-ci, and the build result is pushed to
mapserver.org.
thomas
On 5 May 2015 at 23:25, Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
> Hi devs,
> I notice that our Sphinx installation version (the software that we use to
> convert from restructured text to html files automagically) on mapserver.org
> is a deprecated 1.1.3 . As noted in our Documentation Guide[1], our docs
> process (including the translations) requires a minimum Sphinx version of
> 1.2b3
> I'm not running Sphinx 1.3.1 locally.
> But now how to upgrade the mapserver.org hosted docs to the Sphinx 1.3.1
> release, is the challenge.
> I have logged into the ProjectsVM and upgraded Sphinx on that machine to
> 1.3.1 (through the 'easy_install' command)  But I haven't seen any changes
> to mapserver.org (you can see the Sphinx version listed at the bottom of
> every page).
> So, question:
> Can someone assist me to upgrade Sphinx 1.3.1 on mapserver.org ?  I don't
> need much of your time, only a few notes on how to upgrade and then I can
> run the commands on the server (I will also update the Documentation Guide
> with these steps, so people like myself can remember ha!).
> Thanks!
> -jeff
> [1]
> http://www.mapserver.org/development/documentation.html#installing-and-using-sphinx-for-rst-html-generation
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
