[mapserver-dev] Upgrading Sphinx/Docs to 1.3.1
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed May 6 13:47:52 PDT 2015
Thanks for the tips Thomas and Tom. In the end all I needed was a
"requirements.txt" file in the root, containing one line of "sphinx==1.3.1"
Will add this to the Documentation Guide.
Thanks!
-jeff
On 2015-05-06 1:49 PM, Jeff McKenna wrote:
> Thanks Tom, I was wondering that too...thanks for pointing to this, I'll
> give it a try!
> -jeff
> On 2015-05-06 1:35 PM, Tom Kralidis wrote:
>> I think we have to change the Sphinx that gets installed in Travis?
>> https://github.com/mapserver/docs/blob/branch-6-4/.travis.yml#L28
>> I think using pip install sphinx==1.3.1 instead of apt will peg to the
>> version properly.
>> Sent from my iPhone
>> On May 6, 2015, at 09:43, Jeff McKenna <jmckenna at gatewaygeomatics.com
>> <mailto:jmckenna at gatewaygeomatics.com>> wrote:
>>> Hi Thomas,
>>> Interesting. Though that leaves me with the same question: can
>>> someone assist me to upgrade to Sphinx 1.3.1 on mapserver.org
>>> <http://mapserver.org>?
>>> I explained in previous messages as to why we must not use a Sphinx
>>> version from several years ago for our docs (March 2012 in fact).
>>> -jeff
>>> On 2015-05-06 3:32 AM, thomas bonfort wrote:
>>>> Jeff,
>>>> the docs are built on travis-ci, and the build result is pushed to
>>>> mapserver.org <http://mapserver.org>.
>>>> thomas
>>>> On 5 May 2015 at 23:25, Jeff McKenna <jmckenna at gatewaygeomatics.com
>>>>> Hi devs,
>>>>> I notice that our Sphinx installation version (the software that we
>>>>> use to
>>>>> convert from restructured text to html files automagically) on
>>>>> is a deprecated 1.1.3 . As noted in our Documentation Guide[1], our
>>>>> docs
>>>>> process (including the translations) requires a minimum Sphinx
>>>>> version of
>>>>> 1.2b3
>>>>> I'm not running Sphinx 1.3.1 locally.
>>>>> But now how to upgrade the mapserver.org <http://mapserver.org>
>>>>> hosted docs to the Sphinx 1.3.1
>>>>> release, is the challenge.
>>>>> I have logged into the ProjectsVM and upgraded Sphinx on that
>>>>> machine to
>>>>> 1.3.1 (through the 'easy_install' command) But I haven't seen any
>>>>> changes
>>>>> to mapserver.org <http://mapserver.org> (you can see the Sphinx
>>>>> version listed at the bottom of
>>>>> every page).
>>>>> So, question:
>>>>> Can someone assist me to upgrade Sphinx 1.3.1 on mapserver.org
>>>>> <http://mapserver.org> ? I don't
>>>>> need much of your time, only a few notes on how to upgrade and then
>>>>> I can
>>>>> run the commands on the server (I will also update the Documentation
>>>>> Guide
>>>>> with these steps, so people like myself can remember ha!).
>>>>> Thanks!
>>>>> -jeff
>>>>> [1]
>>>>> http://www.mapserver.org/development/documentation.html#installing-and-using-sphinx-for-rst-html-generation
