[mapserver-dev] Documention update (i18n)
Jeff McKenna
jmckenna at gatewaygeomatics.com
Sun May 17 13:24:32 PDT 2015
Great, thanks Yves!
-jeff
On 2015-05-17 4:07 PM, Yves Jacolin wrote:
> hello,
> I successfully update the translation of the documentation. I have also
> update how to do it in the documentation.
> Thanks,
> Y.
> 2015-05-17 14:06 GMT+02:00 Yves Jacolin <yves.jacolin at camptocamp.com
> <mailto:yves.jacolin at camptocamp.com>>:
> Hello,
> I just pushed translation file to transifex from branch-7.0. I also
> pull
> translated file from transifex and pushed them into branch-7.0.
> Everything is uptodate now (well "should be"). If you think there
> are some
> problem, just send me a message here or in transifex.
> I also enabled all language in Makefile (add it in TRANSLATIONI18N
> parameter +
> LC_MESSAGES directory in each langage.
> Travis is still testing the documentation build processing but I
> guess it will
> be a success.
> I have only one issue that I can't correct. How documentation is
> updated in
> the server? I though it was build on travis-ci and then push on the
> server but
> french and other langage are not uptodate.
> Last thing to tell you QGIS documentation shows in the footer the
> date of the
> last update and a link to transifex. I will try to do something
> similar with
> MapServer to help to find the correct transifex page to correct a typo.
> Thanks,
> Y
> Responsable Formation et Support
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel (France) : +33 4 58 48 20 43 <tel:%2B33%204%2058%2048%2020%2043>
> (new !)
> Tel (Suisse) : +41 21 619 10 43 <tel:%2B41%2021%20619%2010%2043>
> Mob. : +33 6 18 75 42 21 <tel:%2B33%206%2018%2075%2042%2021>
> Fax : 04 79 70 15 81 <tel:04%2079%2070%2015%2081>
> Mail : yves.jacolin at camptocamp.com <mailto:yves.jacolin at camptocamp.com>
> http://www.camptocamp.com
> Tel (France) : +33 4 58 48 20 43 (new !)
