[mapserver-dev] Documention update (i18n)
Yves Jacolin yves.jacolin at camptocamp.com
Sun May 17 07:07:05 PDT 2015
hello,
I successfully update the translation of the documentation. I have also
update how to do it in the documentation.
Thanks,
Y.
2015-05-17 14:06 GMT+02:00 Yves Jacolin <yves.jacolin at camptocamp.com>:
> Hello,
> I just pushed translation file to transifex from branch-7.0. I also pull
> translated file from transifex and pushed them into branch-7.0.
> Everything is uptodate now (well "should be"). If you think there are some
> problem, just send me a message here or in transifex.
> I also enabled all language in Makefile (add it in TRANSLATIONI18N
> parameter +
> LC_MESSAGES directory in each langage.
> Travis is still testing the documentation build processing but I guess it
> will
> be a success.
> I have only one issue that I can't correct. How documentation is updated
> in
> the server? I though it was build on travis-ci and then push on the server
> but
> french and other langage are not uptodate.
> Last thing to tell you QGIS documentation shows in the footer the date of
> the
> last update and a link to transifex. I will try to do something similar
> with
> MapServer to help to find the correct transifex page to correct a typo.
> Thanks,
> Y
> Responsable Formation et Support
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel (France) : +33 4 58 48 20 43 (new !)
> Tel (Suisse) : +41 21 619 10 43
> Mob. : +33 6 18 75 42 21
> Fax : 04 79 70 15 81
> Mail : yves.jacolin at camptocamp.com
> http://www.camptocamp.com
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20150517/6b486461/attachment.html>
