[mapserver-dev] MOTION: Request to change default value of label->partials in next release
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Nov 21 07:18:24 PST 2015
+1 SteveW
On 11/21/2015 4:41 AM, thomas bonfort wrote:
> For context, see https://github.com/mapserver/mapserver/issues/5198.
> If we set label->partials to false by default, then it would not be
> possible to set it back to true through SLD.
> Motion: For MapServer 7.2, set LABEL->PARTIALS to false by default
> instead of true, with a note added about this in the migration guide.
> +1 Thomas
> On 20 November 2015 at 20:53, John Morton <jmorton at ldeo.columbia.edu> wrote:
>> It makes sense in general for the label->partials value to be set to false
>> by default in map files. For WMS, PARTIALS FALSE is always required for
>> proper display in a tiled map, which I'm assuming represents the vast
>> majority of WMS GetMap requests. Also, since SLD provides no elements for
>> toggling off partial labels, any tiled maps styled with SLD instead of map
>> file CLASS blocks will have their labels cut off with no way to modify this
>> behavior. There aren't many use cases where partial labels are desired, so
>> they should probably be the exception rather than the rule.
>> John Morton
>> Lamont-Doherty Earth Observatory
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
