[mapserver-dev] Request to change default value of label->partials in next release
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Sat Nov 21 20:36:06 PST 2015
A good idea, +1 as well. --Steve
________________________________________
From: mapserver-dev [mapserver-dev-bounces at lists.osgeo.org] on behalf of thomas bonfort [thomas.bonfort at gmail.com]
Sent: Saturday, November 21, 2015 3:41 AM
To: John Morton
Cc: MapServer Dev Mailing List
Subject: Re: [mapserver-dev] Request to change default value of label->partials in next release
For context, see https://github.com/mapserver/mapserver/issues/5198.
If we set label->partials to false by default, then it would not be
possible to set it back to true through SLD.
Motion: For MapServer 7.2, set LABEL->PARTIALS to false by default
instead of true, with a note added about this in the migration guide.
+1 Thomas
On 20 November 2015 at 20:53, John Morton <jmorton at ldeo.columbia.edu> wrote:
> It makes sense in general for the label->partials value to be set to false
> by default in map files. For WMS, PARTIALS FALSE is always required for
> proper display in a tiled map, which I'm assuming represents the vast
> majority of WMS GetMap requests. Also, since SLD provides no elements for
> toggling off partial labels, any tiled maps styled with SLD instead of map
> file CLASS blocks will have their labels cut off with no way to modify this
> behavior. There aren't many use cases where partial labels are desired, so
> they should probably be the exception rather than the rule.
> John Morton
> Lamont-Doherty Earth Observatory
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
