[mapserver-dev] MOTION: Request to change default value of label->partials in next release
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Sun Nov 22 04:48:40 PST 2015
+1 for setting LABEL->PARTIALS to false by default.
On the other hand, we might pay a bit more attention to SLD support. This issue arose from the mapserver-users mail where a user was hoping to change the LABEL PARTIALS setting with SLD. This option is not a part of the SLD standard and in such case the GeoServer project is introducing their own extensions to SLD.
What I fear is that we may have some styling options which are not exposed to SLD and if user does a round trip with GetStyles - change something that certainly is part of SLD like fill color - tell Mapserver to use the modified SLD then the result can be that it is not only the color that was changed.
-Jukka Rahkonen-
________________________________________
Jeff McKenna wrote:
>> Motion: For MapServer 7.2, set LABEL->PARTIALS to false by default
>> instead of true, with a note added about this in the migration guide.
+1
-jeff
mapserver-dev mailing list
mapserver-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
