[mapserver-dev] Request to change default value of label->partials in next release
Oliver Courtin olivier.courtin at oslandia.com
Mon Nov 23 06:13:46 PST 2015
Le 22 nov. 2015 à 15:40, Daniel Morissette a écrit :
> +0  I can appreciate that this change would help the SLD case and I have no strong objection to the change,
> but we should keep in mind that it could cause side-effects to other use cases that relied on this default value being TRUE by default for years, hence the +0.
+1 with Daniel, so +0 :)
O.
