[mapserver-dev] Request to change default value of label->partials in next release
Stephan Meißl stephan at meissl.name
Mon Nov 23 05:11:46 PST 2015
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
+1
Stephan
On 11/21/2015 10:41 AM, thomas bonfort wrote:
> For context, see https://github.com/mapserver/mapserver/issues/5198.
> If we set label->partials to false by default, then it would not be
> possible to set it back to true through SLD.
> Motion: For MapServer 7.2, set LABEL->PARTIALS to false by default
> instead of true, with a note added about this in the migration guide.
> +1 Thomas
> On 20 November 2015 at 20:53, John Morton <jmorton at ldeo.columbia.edu>
wrote:
>> It makes sense in general for the label->partials value to be set to
false
>> by default in map files. For WMS, PARTIALS FALSE is always required f
or
>> proper display in a tiled map, which I'm assuming represents the vast
>> majority of WMS GetMap requests. Also, since SLD provides no elements
 for
>> toggling off partial labels, any tiled maps styled with SLD instead o
f map
>> file CLASS blocks will have their labels cut off with no way to modif
y this
>> behavior. There aren't many use cases where partial labels are desire
d, so
>> they should probably be the exception rather than the rule.
>> John Morton
>> Lamont-Doherty Earth Observatory
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.22 (GNU/Linux)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=Qu3r
-----END PGP SIGNATURE-----
