[mapserver-dev] Request to change default value of label->partials in next release
Perry Nacionales
pnaciona at gmail.com
Mon Nov 23 05:55:19 PST 2015
+1
PerryN
On Nov 23, 2015 07:17, "Stephan Meißl" <stephan at meissl.name> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> +1
> Stephan
> On 11/21/2015 10:41 AM, thomas bonfort wrote:
> > For context, see https://github.com/mapserver/mapserver/issues/5198.
> > If we set label->partials to false by default, then it would not be
> > possible to set it back to true through SLD.
> > Motion: For MapServer 7.2, set LABEL->PARTIALS to false by default
> > instead of true, with a note added about this in the migration guide.
> > +1 Thomas
> > On 20 November 2015 at 20:53, John Morton <jmorton at ldeo.columbia.edu>
> wrote:
> >> It makes sense in general for the label->partials value to be set to
> false
> >> by default in map files. For WMS, PARTIALS FALSE is always required f
> or
> >> proper display in a tiled map, which I'm assuming represents the vast
> >> majority of WMS GetMap requests. Also, since SLD provides no elements
> for
> >> toggling off partial labels, any tiled maps styled with SLD instead o
> f map
> >> file CLASS blocks will have their labels cut off with no way to modif
> y this
> >> behavior. There aren't many use cases where partial labels are desire
> d, so
> >> they should probably be the exception rather than the rule.
> >> John Morton
> >> Lamont-Doherty Earth Observatory
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v2.0.22 (GNU/Linux)
> iQIcBAEBAgAGBQJWUxCSAAoJEKNQXeNWi+qta2oP/iTNEHtq6cuUmMzodaY/MVxi
> 7SGATULthNjgQG6XKEIXZjs/cgywV+hkZUe95enkCmKoR3YJ3qTrwa8BaAMOzgDd
> mG65xAd7spi6Hq3lDqsUXdPdaged4TezqrRkyCTiufSknPTf5kWFbPXxVqdo3gFz
> tQNsE0ctHMeobwrie03OyFhVDef1+AiSc0KxE0kXHKeh1+DvNu4rF2+b8TOapSSg
> tJ1HCeBzyZmWr+POWLUHz5A8+W6E7S7V9WTLrmjllWXbLW0t3UbcXg7BU0CSFgrE
> CMHK8l6rMBeSGb17pnZxHCUPofarm8vbEIkXaC+RKsdzbpxIYAM7hV8QXnufkLmw
> 5H1I7rtjWqTEc6TJKZfFNpURIUlwilnoCqoRL1rLJJCwSnZUMLYGLGxvL0iKO1P1
> EEs481EgvEwWoQqvqjBOWgX13go21jtmjU/urquSl4Wv/hxxQKkzQbwrz0q58ZkN
> 0b1+MMJ++AOoJGYiDisBkQ3Ooa65K3K1L8wb10uUHo7C9SONPjL0t8PgYjy50uJK
> DwubAmgv6BgZNDc+rulr+J8sXgopUVYH2JlNJWn0aLOCb8zUWDsGO8ZBUcTmjUeE
> /XXSq2p8z2ecQDHBvyUayuqVw/HsuITUndOz1vijl8hzWFxrDajhbDqVqyLs1DEo
> mnxAS3J26gH9t2HIXrCQ
> =Qu3r
> -----END PGP SIGNATURE-----
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20151123/7f1e2d61/attachment.html>
