[mapserver-dev] Request to change default value of label->partials in next release
Tom Kralidis
tomkralidis at gmail.com
Mon Nov 23 05:56:30 PST 2015
+1
..Tom
On Mon, 23 Nov 2015, Perry Nacionales wrote:
> Date: Mon, 23 Nov 2015 07:55:19 -0600
> From: Perry Nacionales <pnaciona at gmail.com>
> To: Stephan Meißl <stephan at meissl.name>
> Cc: mapserver-dev <mapserver-dev at lists.osgeo.org>
> Subject: Re: [mapserver-dev] Request to change default value of
> +1
> PerryN
> On Nov 23, 2015 07:17, "Stephan Meißl" <stephan at meissl.name> wrote:
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> +1
>> Stephan
>> On 11/21/2015 10:41 AM, thomas bonfort wrote:
>>> For context, see https://github.com/mapserver/mapserver/issues/5198.
>>> If we set label->partials to false by default, then it would not be
>>> possible to set it back to true through SLD.
>>> Motion: For MapServer 7.2, set LABEL->PARTIALS to false by default
>>> instead of true, with a note added about this in the migration guide.
>>> +1 Thomas
>>> On 20 November 2015 at 20:53, John Morton <jmorton at ldeo.columbia.edu>
>> wrote:
>>>> It makes sense in general for the label->partials value to be set to
>> false
>>>> by default in map files. For WMS, PARTIALS FALSE is always required f
>> or
>>>> proper display in a tiled map, which I'm assuming represents the vast
>>>> majority of WMS GetMap requests. Also, since SLD provides no elements
>> for
>>>> toggling off partial labels, any tiled maps styled with SLD instead o
>> f map
>>>> file CLASS blocks will have their labels cut off with no way to modif
>> y this
>>>> behavior. There aren't many use cases where partial labels are desire
>> d, so
>>>> they should probably be the exception rather than the rule.
>>>> John Morton
>>>> Lamont-Doherty Earth Observatory
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v2.0.22 (GNU/Linux)
>> iQIcBAEBAgAGBQJWUxCSAAoJEKNQXeNWi+qta2oP/iTNEHtq6cuUmMzodaY/MVxi
>> 7SGATULthNjgQG6XKEIXZjs/cgywV+hkZUe95enkCmKoR3YJ3qTrwa8BaAMOzgDd
>> mG65xAd7spi6Hq3lDqsUXdPdaged4TezqrRkyCTiufSknPTf5kWFbPXxVqdo3gFz
>> tQNsE0ctHMeobwrie03OyFhVDef1+AiSc0KxE0kXHKeh1+DvNu4rF2+b8TOapSSg
>> tJ1HCeBzyZmWr+POWLUHz5A8+W6E7S7V9WTLrmjllWXbLW0t3UbcXg7BU0CSFgrE
>> CMHK8l6rMBeSGb17pnZxHCUPofarm8vbEIkXaC+RKsdzbpxIYAM7hV8QXnufkLmw
>> 5H1I7rtjWqTEc6TJKZfFNpURIUlwilnoCqoRL1rLJJCwSnZUMLYGLGxvL0iKO1P1
>> EEs481EgvEwWoQqvqjBOWgX13go21jtmjU/urquSl4Wv/hxxQKkzQbwrz0q58ZkN
>> 0b1+MMJ++AOoJGYiDisBkQ3Ooa65K3K1L8wb10uUHo7C9SONPjL0t8PgYjy50uJK
>> DwubAmgv6BgZNDc+rulr+J8sXgopUVYH2JlNJWn0aLOCb8zUWDsGO8ZBUcTmjUeE
>> /XXSq2p8z2ecQDHBvyUayuqVw/HsuITUndOz1vijl8hzWFxrDajhbDqVqyLs1DEo
>> mnxAS3J26gH9t2HIXrCQ
>> =Qu3r
>> -----END PGP SIGNATURE-----
>> mapserver-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
