[mapserver-dev] Request to change default value of label->partials in next release
Michael Smith
michael.smith.erdc at gmail.com
Mon Nov 23 06:03:53 PST 2015
+1 Mike
On 11/23/15, 8:56 AM, "mapserver-dev on behalf of Tom Kralidis"
<mapserver-dev-bounces at lists.osgeo.org on behalf of tomkralidis at gmail.com>
wrote:
>+1
>..Tom
>On Mon, 23 Nov 2015, Perry Nacionales wrote:
>> Date: Mon, 23 Nov 2015 07:55:19 -0600
>> From: Perry Nacionales <pnaciona at gmail.com>
>> To: Stephan Meißl <stephan at meissl.name>
>> Cc: mapserver-dev <mapserver-dev at lists.osgeo.org>
>> Subject: Re: [mapserver-dev] Request to change default value of
>> +1
>> PerryN
>> On Nov 23, 2015 07:17, "Stephan Meißl" <stephan at meissl.name> wrote:
>>> -----BEGIN PGP SIGNED MESSAGE-----
>>> Hash: SHA1
>>> +1
>>> Stephan
>>> On 11/21/2015 10:41 AM, thomas bonfort wrote:
>>>> For context, see https://github.com/mapserver/mapserver/issues/5198.
>>>> If we set label->partials to false by default, then it would not be
>>>> possible to set it back to true through SLD.
>>>> Motion: For MapServer 7.2, set LABEL->PARTIALS to false by default
>>>> instead of true, with a note added about this in the migration guide.
>>>> +1 Thomas
>>>> On 20 November 2015 at 20:53, John Morton <jmorton at ldeo.columbia.edu>
>>> wrote:
>>>>> It makes sense in general for the label->partials value to be set to
>>> false
>>>>> by default in map files. For WMS, PARTIALS FALSE is always required f
>>> or
>>>>> proper display in a tiled map, which I'm assuming represents the vast
>>>>> majority of WMS GetMap requests. Also, since SLD provides no elements
>>> for
>>>>> toggling off partial labels, any tiled maps styled with SLD instead o
>>> f map
>>>>> file CLASS blocks will have their labels cut off with no way to modif
>>> y this
>>>>> behavior. There aren't many use cases where partial labels are desire
>>> d, so
>>>>> they should probably be the exception rather than the rule.
>>>>> John Morton
>>>>> Lamont-Doherty Earth Observatory
>>> -----BEGIN PGP SIGNATURE-----
>>> Version: GnuPG v2.0.22 (GNU/Linux)
>>> iQIcBAEBAgAGBQJWUxCSAAoJEKNQXeNWi+qta2oP/iTNEHtq6cuUmMzodaY/MVxi
>>> 7SGATULthNjgQG6XKEIXZjs/cgywV+hkZUe95enkCmKoR3YJ3qTrwa8BaAMOzgDd
>>> mG65xAd7spi6Hq3lDqsUXdPdaged4TezqrRkyCTiufSknPTf5kWFbPXxVqdo3gFz
>>> tQNsE0ctHMeobwrie03OyFhVDef1+AiSc0KxE0kXHKeh1+DvNu4rF2+b8TOapSSg
>>> tJ1HCeBzyZmWr+POWLUHz5A8+W6E7S7V9WTLrmjllWXbLW0t3UbcXg7BU0CSFgrE
>>> CMHK8l6rMBeSGb17pnZxHCUPofarm8vbEIkXaC+RKsdzbpxIYAM7hV8QXnufkLmw
>>> 5H1I7rtjWqTEc6TJKZfFNpURIUlwilnoCqoRL1rLJJCwSnZUMLYGLGxvL0iKO1P1
>>> EEs481EgvEwWoQqvqjBOWgX13go21jtmjU/urquSl4Wv/hxxQKkzQbwrz0q58ZkN
>>> 0b1+MMJ++AOoJGYiDisBkQ3Ooa65K3K1L8wb10uUHo7C9SONPjL0t8PgYjy50uJK
>>> DwubAmgv6BgZNDc+rulr+J8sXgopUVYH2JlNJWn0aLOCb8zUWDsGO8ZBUcTmjUeE
>>> /XXSq2p8z2ecQDHBvyUayuqVw/HsuITUndOz1vijl8hzWFxrDajhbDqVqyLs1DEo
>>> mnxAS3J26gH9t2HIXrCQ
>>> =Qu3r
>>> -----END PGP SIGNATURE-----
>>> mapserver-dev mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
