[mapserver-dev] RFC 112: offset FOLLOW labels when self collisions are detected
thomas bonfort
thomas.bonfort at gmail.com
Wed Nov 25 05:28:25 PST 2015
+1 from me also for the record.
The corresponding code has been pushed to the master branch and will
be available in 7.2
thomas
On 12 December 2014 at 23:01, Stephen Woodbridge
<woodbri at swoodbridge.com> wrote:
> FYI: I'm +1 on both questions.
> And agree the we can add controls later if there is a need.
> Thanks,
> -Steve W
> On 12/11/2014 6:13 PM, Lime, Steve D (MNIT) wrote:
>> Configuration could always be added later if it is determined to be
>> necessary. I agree that not having to fiddle is a good thing and lessens the
>> learning curve.
>> So, I'm +1 for the RFC "as is" and +1 for including in 7.0.
>> Steve
>> -----Original Message-----
>> From: mapserver-dev-bounces at lists.osgeo.org
>> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Stephen
>> Woodbridge
>> Sent: Wednesday, December 10, 2014 8:31 AM
>> To: mapserver-dev at lists.osgeo.org
>> Subject: Re: [mapserver-dev] RFC 112: offset FOLLOW labels when self
>> On 12/10/2014 3:49 AM, thomas bonfort wrote:
>>> Hi Devs,
>>> Please have a look at
>>> http://mapserver.org/development/rfc/ms-rfc-112.html
>>> The RFC is very short and contains an open question as to whether the
>>> proposed behavior should be configurable or not (I don't think it
>>> needs to be) Given how much the 7.0 release has slipped already, and
>>> the limited implications of the change, I would like this to be
>>> applied to master before we create 7.0 stable branch.
>> This sounds reasonable to me. I like being able to configure things, but I
>> like it better when they just work nicely without a lot of fiddling because
>> it makes it a lot easier for users. So unless there is some great need to
>> have additional configuration parameters I would leave them out.
>> Thanks,
>> -Steve W
>> mapserver-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
