[mapserver-dev] php-mapscript missing from Ubuntu 16.04 beta?
Worth Lutz wal3 at mindspring.com
Mon Apr 4 12:33:29 PDT 2016
I've done more googling and I now see that both 5 and 7 were in the
beta2 release to keep from breaking too much.
And I see that the final release will be only php7. [1]  This is
confirmed at the bottom of this issue.
What is needed to get php-mapscript working on php7?
[1]  https://bugs.launchpad.net/ubuntu/+source/php5/+bug/1522422
*Worth Lutz*
On 04/04/2016 03:07 PM, Worth Lutz wrote:
> Maybe I just don't know what I'm talking about but isn't php5 still on
> Ubuntu 16.04.
> When I setup this new test vm, I installed php5 and php5-pgsql.
> phpinfo shows version 5.6.17.
> Would not php5-mapscript work with this? Will php5 not be in the
> actual release?
> I see packages labeled php7.0.  Are these the php7 you are talking
> about?  I did not install that as I did not know there was the option.
> I'm confused by all this and will not be able to upgrade my servers if
> php-mapscript is not available.
> Thanks,
> *Worth Lutz*
> On 4/4/2016 2:38 PM, Sebastiaan Couwenberg wrote:
>> On 04/04/2016 07:28 PM, Worth Lutz wrote:
>>> I downloaded a version of Ubuntu 16.04 beta to try it out.  It seems
>>> that php5-mapscript in missing. i do not see it in apt-cache search.
>>> Or maybe I'm just missing something.  I'm trying to set up just as I did
>>> in 14.04.
>>> Has something changed?
>> MapScript doesn't support PHP 7 yet, see:
>> https://github.com/mapserver/mapserver/issues/5252
>> https://bugs.launchpad.net/ubuntu/+source/swig/+bug/1546823
>> Kind Regards,
>> Bas
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20160404/dd90c25c/attachment.html>
