[mapserver-dev] PHP 7 MapScript SWIG Support / Discussion
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Dec 20 13:58:30 PST 2016
Regarding the clone() keyword, I looked closer at the MapServer source,
and in fact Java MapScript faced the same issue apparently, and handled
that by defining a new function name for those use cases (cloning map,
layer, class, style, shape instances) such as:
#ifdef SWIGJAVA
%newobject cloneMap;
mapObj *cloneMap()
#else
%newobject clone;
mapObj *clone()
#endif
So we would do the same for SWIGPHP (reference them in the /swiginc/
files and define those functions in /mapscript/php/phpextend.i
(I've updated the RFC with those notes)
Thanks for the feedback Ducky!
-jeff
On 2016-12-19 10:49 AM, Dan Little wrote:
> I'm generally positive about this in the hopes that it means the
> PHP/MapScript+SWIG will ensure PHP gets feature parity with the other
> versions of MapScript. I also am a fan of what looks to be a more
> consistent syntax to modern PHP.
> I'll venture an opinion/suggestions on the reserved word cases
> (specifically clone and close): Is there a way to alias those
> function names to something other than "c_..." ? If so, I've seen
> some convention such as "clone_" or "close_", and more PHP-y might be
> something to the tune of "cloneInstance()" or "closeXYZ" where XYZ is
> actual context appropriate (closeStream, closeConnection, etc.).
> Cheers.
> On Mon, Dec 19, 2016 at 9:47 AM, Dan Little <theduckylittle at gmail.com> wrote:
>> Cheers.
>> On Fri, Dec 16, 2016 at 4:32 PM, Jeff McKenna
>> <jmckenna at gatewaygeomatics.com> wrote:
>>> Hi all,
>>> I've created an RFC draft for the PHP 7 SWIG potential changes:
>>> http://mapserver.org/development/rfc/ms-rfc-117.html
>>> Please pay attention to the "Limitations" section, as there are some items
>>> that need discussion. I will plan to discuss this for sure at the next PSC
>>> meeting on 19 January, so we have lots of time to discuss, especially as we
>>> are entering the holidays.
>>> Wishing the whole MapServer community a truly happy and merry Christmas! :)
>>> -jeff
