[mapserver-dev] [EXTERNAL] Problem with filter in Oracle
Björn Danielsson
bjorn.danielsson at falubo.se
Mon Jan 18 00:33:03 PST 2016
Hi Michael,
Sorry, I did not notice that I only replied to your private address.
Anyway, I followed your advice and set DEBUG 3 in layer 'X', and made two
runs: one with filter set and one with filter not set. The debug output for
both runs is in the included ms_error.txt-file.
The one with filter set produce an empty image. The one with filter not set
works fine.
I took the statement from 'Using this Sql to retrieve data', replaced :srid
with -1 and :ordinates with
SDO_ORDINATE_ARRAY(393339.5,6773950.0,394169.5,6774780.0) and ran the
statement in sqlplus.
Both examples worked.
So I am a bit at loss. The only thing I can see in the debug file is that
:ordinates is not declared in 'Bind values' but the rectangle's extents are.
But I don't know what goes on behind the scene so that might be correct. It
feels strange though that this would affect the filter. Or can it be that
oracle spatial detects that the table ( when filter not set ) contains only
one record and therefore skip the sdo-filtering altogether?
Björn D
-----Original Message-----
From: Michael Smith <michael.smith.erdc at gmail.com>
To: Björn Danielsson <bjorn.danielsson at falubo.se>,
<mapserver-users at lists.osgeo.org>
Date: Fri, 15 Jan 2016 07:04:55 -0500
Subject: Re: [EXTERNAL] [mapserver-dev] Problem with filter in Oracle
Always reply back to the list, others can assist also.
You need to set the DEBUG 3 at the layer level in your mapfile and then the
actual queries sent to Oracle will be displayed in the log file (as well as
any spatial bind values). Then you can run those queries outside of
mapserver and verify whether you are getting the rows of data you expect or
not.
Mike
Michael Smith
US Army Corps
Remote Sensing GIS/Center
michael.smith at usace.army.mil
From: Björn Danielsson < bjorn.danielsson at falubo.se>
Date: Friday, January 15, 2016 at 2:40 AM
To: Michael Smith <michael.smith.erdc at gmail.com >
Hi Michael and thanks for your quick response.
I did 3 runs with debuglevel 3 and the outcome from the debugger does not
say me much.
DEBUG 3
CONFIG "MS_ERRORFILE" "/ms4w/tmp/ms_error.txt"
I also activated the 'debugger' in my php scripts that writes a lot, among
other things the database calls, to a file.
The three runs and the resulting debug files are called A,B and C. From
mapserver debug 'ms_error_A.txt', and from php debug 'php_debug_A.log'. Look
for 'filter = ' in the php debug files.
A, B and C refer to the examples in my original mail.
Run A shows the example:
$filter = "([ID]='".$sessid."')";
with the layers 'AVD' and 'X' where 'AVD' works fine and 'X' does not.
Run B and C is from the same php script with different contents in filter.
Look for layers 'AVD' and 'AVD-L'. Actually the same table and column. Layer
'AVD' shows polygons and layer 'AVD-L' the polygons' outlines.
Run C works and run B does not.
The column SKIFTE in run B is surrounded by parenthesis because it may be
like (SKIFTE='A' OR SKIFTE='C' OR ...) because mapserver obviously no longer
supports the 'in'-statement. I have tried without parenthesis but that did
not change anything.
I can't see any pattern in this.
Björn Danielsson
From: Michael Smith < michael.smith.erdc at gmail.com>
To: Björn Danielsson < bjorn.danielsson at falubo.se>,
"mapserver-dev at lists.osgeo.org " < mapserver-dev at lists.osgeo.org>
Date: Thu, 14 Jan 2016 09:35:31 -0500
Björn,
Can you turn on DEBUG level 3 and show what queries are being generated?
That will help isolate whats going on with the queries to the backend.
Mike
Michael Smith
Remote Sensing/GIS Center
US Army Corps of Engineers
From: mapserver-dev < mapserver-dev-bounces at lists.osgeo.org> on behalf of
Date: Thursday, January 14, 2016 at 4:30 AM
To: "mapserver-dev at lists.osgeo.org " < mapserver-dev at lists.osgeo.org>
Subject: [EXTERNAL] [mapserver-dev] Problem with filter in Oracle
Resent-From: Michael Smith <michael.smith at usace.army.mil >
I have been using ms4w for quite some time and have discovered problems with
Oracle when using php_mapscript. I posted this problem at ms4w's support and
was adviced to turn to you.
I am supporting a gis-system on the web that is heavily database dependent,
and can run on either postgres or oracle according to the costumer's
request. So there are two sets of php-scripts that are identical apart from
the database calls.
Thera are no problems with postgres.
With Oracle there is a funny problem with filter.
Look at this:
foreach($aLayersIdx as $layerIndex) {
$oLayerK = $oMapK->getLayer($layerIndex);
if ($bDebug) {
fwrite($f,"layer: ".$oLayerK->name."\r\n");
if ($oLayerK->name == "AVD" && $avd == "") {
$oLayerK->set("status",MS_OFF);
continue;
$filter = "";
switch ($oLayerK->name) {
case "AVD" :
$filter = "([ORGID]='".$orgid."' AND [FV]='".$fv."' AND
[BEV]='".$bev."' AND [SKIFTE]='".$skifte."' AND [AVD]='".$avd."')";
$data = "KARTOBJ_SDO FROM ".$dbowner.".AVD*AVD";
break;
case "X" :
$data = "KARTOBJ_SDO FROM ".$dbowner.".KARTA*TMP2";
break;
$data = str_replace("*","$",$data);
$oLayerK->set("data", $data);
$oLayerK->setFilter($filter);
$oLayerK->setConnectionType(MS_ORACLESPATIAL);
$oLayerK->set("connection", $conn);
$oLayerK->set("status", MS_ON);
if ($bDebug) {
fwrite($f,"connection: ".$conn."\r\n");
fwrite($f,"filter: ".$filter."\r\n");
fwrite($f,"data: ".$data."\r\n");
A mapfile with two layers, 'AVD' and 'X'.
Problem is that filter for layer 'X' does not work. Or, rather, it works but
no record is returned. The mapserver debugger reports no error.
The filter for layer 'AVD' works fine.
When the line $filter = "[ID]='".$sessid."')" is commented and the table
KARTA$TMP2 contains only one record it works and a map layer is produced. So
it seems that when filter is introduced in the select something goes wrong.
I thought that ID might be a reserved word but after some testing I found
that filter fails in calls to other tables as well.
For example:
This works
[BEV]='".$bev."')";
But this does not work
[BEV]='".$bev."' AND [SKIFTE]='".$skifte."')";
The problem is consistent in that way that where the problem occurs it
always occurs, and where it not occurs it never occurs. It is not
intermittent.
The php script ( where the snippet came from above ) was developed under
ms4w version 2.2.7 and at that time no problems occured. I have also used
version 3.0.6 and 3.1.1 and both versions have problems. So somewhere
between 2.2.7 and 3.0.6 something happened.
I am at loss here.
Björn Danielsson
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20160118/cf772bb9/attachment-0001.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20160118/cf772bb9/attachment-0001.txt>
