[mapserver-dev] [EXTERNAL] Problem with filter in Oracle
Michael Smith
michael.smith.erdc at gmail.com
Mon Jan 18 04:43:31 PST 2016
No, there is no check on the number of records. In both queries, the spatial
filter is passed but in the second one, there is no other filter.
If both queries are returning rows in sqlplus, then I think you need to look
at the rendering side. Perhaps you have something that is preventing the
image from drawing if ID is set?
You can also increase the DEBUG value to 5 and see the rows produced by each
query but if both are producing rows in sqlplus, they should in mapserver.
And the :ordinates bind value does include the sdo_ordinate_array type being
passed.
First query:
SELECT ID, rownum, KARTOBJ_SDO FROM c2.KARTA$TMP2 WHERE ID =
'1eokfraqi19niup7402g3iflp7' AND SDO_FILTER( KARTOBJ_SDO,
MDSYS.SDO_GEOMETRY(2003, :srid,
NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),:ordinates),'querytype=window') =
'TRUE'
Second query:
SELECT rownum, KARTOBJ_SDO FROM c2.KARTA$TMP2 WHERE SDO_FILTER( KARTOBJ_SDO,
'TRUE'
Mike
From: Björn Danielsson <bjorn.danielsson at falubo.se>
Date: Monday, January 18, 2016 at 3:33 AM
To: Michael Smith <michael.smith.erdc at gmail.com>
Cc: <mapserver-dev at lists.osgeo.org>
Subject: Re: [EXTERNAL] [mapserver-dev] Problem with filter in Oracle
> Hi Michael,
> Sorry, I did not notice that I only replied to your private address.
> Anyway, I followed your advice and set DEBUG 3 in layer 'X', and made two
> runs: one with filter set and one with filter not set. The debug output for
> both runs is in the included ms_error.txt-file.
> The one with filter set produce an empty image. The one with filter not set
> works fine.
> I took the statement from 'Using this Sql to retrieve data', replaced :srid
> with -1 and :ordinates with
> SDO_ORDINATE_ARRAY(393339.5,6773950.0,394169.5,6774780.0) and ran the
> statement in sqlplus.
> Both examples worked.
> So I am a bit at loss. The only thing I can see in the debug file is that
> :ordinates is not declared in 'Bind values' but the rectangle's extents are.
> But I don't know what goes on behind the scene so that might be correct. It
> feels strange though that this would affect the filter. Or can it be that
> oracle spatial detects that the table ( when filter not set ) contains only
> one record and therefore skip the sdo-filtering altogether?
> Björn D
>> -----Original Message-----
>> From: Michael Smith <michael.smith.erdc at gmail.com>
>> To: Björn Danielsson <bjorn.danielsson at falubo.se>,
>> <mapserver-users at lists.osgeo.org>
>> Date: Fri, 15 Jan 2016 07:04:55 -0500
>> Always reply back to the list, others can assist also.
>> You need to set the DEBUG 3 at the layer level in your mapfile and then the
>> actual queries sent to Oracle will be displayed in the log file (as well as
>> any spatial bind values). Then you can run those queries outside of mapserver
>> and verify whether you are getting the rows of data you expect or not.
>> Mike
>> Michael Smith
>> US Army Corps
>> Remote Sensing GIS/Center
>> michael.smith at usace.army.mil
>> From: Björn Danielsson < bjorn.danielsson at falubo.se
>> <mailto:bjorn.danielsson at falubo.se> >
>> Date: Friday, January 15, 2016 at 2:40 AM
>> To: Michael Smith <michael.smith.erdc at gmail.com >
>>> Hi Michael and thanks for your quick response.
>>> I did 3 runs with debuglevel 3 and the outcome from the debugger does not
>>> say me much.
>>> DEBUG 3
>>> CONFIG "MS_ERRORFILE" "/ms4w/tmp/ms_error.txt"
>>> I also activated the 'debugger' in my php scripts that writes a lot, among
>>> other things the database calls, to a file.
>>> The three runs and the resulting debug files are called A,B and C. From
>>> mapserver debug 'ms_error_A.txt', and from php debug 'php_debug_A.log'. Look
>>> for 'filter = ' in the php debug files.
>>> A, B and C refer to the examples in my original mail.
>>> Run A shows the example:
>>> $filter = "([ID]='".$sessid."')";
>>> with the layers 'AVD' and 'X' where 'AVD' works fine and 'X' does not.
>>> Run B and C is from the same php script with different contents in filter.
>>> Look for layers 'AVD' and 'AVD-L'. Actually the same table and column. Layer
>>> 'AVD' shows polygons and layer 'AVD-L' the polygons' outlines.
>>> Run C works and run B does not.
>>> The column SKIFTE in run B is surrounded by parenthesis because it may be
>>> like (SKIFTE='A' OR SKIFTE='C' OR ...) because mapserver obviously no longer
>>> supports the 'in'-statement. I have tried without parenthesis but that did
>>> not change anything.
>>> I can't see any pattern in this.
>>> Björn Danielsson
>>>> From: Michael Smith < michael.smith.erdc at gmail.com
>>>> <mailto:michael.smith.erdc at gmail.com> >
>>>> To: Björn Danielsson < bjorn.danielsson at falubo.se
>>>> <mailto:bjorn.danielsson at falubo.se> >, "mapserver-dev at lists.osgeo.org " <
>>>> mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org> >
>>>> Date: Thu, 14 Jan 2016 09:35:31 -0500
>>>> Björn,
>>>> Can you turn on DEBUG level 3 and show what queries are being generated?
>>>> That will help isolate whats going on with the queries to the backend.
>>>> Mike
>>>> Michael Smith
>>>> Remote Sensing/GIS Center
>>>> US Army Corps of Engineers
>>>> From: mapserver-dev < mapserver-dev-bounces at lists.osgeo.org
>>>> <mailto:mapserver-dev-bounces at lists.osgeo.org> > on behalf of Björn
>>>> Danielsson < bjorn.danielsson at falubo.se <mailto:bjorn.danielsson at falubo.se>
>>>> Date: Thursday, January 14, 2016 at 4:30 AM
>>>> To: "mapserver-dev at lists.osgeo.org " < mapserver-dev at lists.osgeo.org
>>>> Subject: [EXTERNAL] [mapserver-dev] Problem with filter in Oracle
>>>> Resent-From: Michael Smith <michael.smith at usace.army.mil >
>>>>> Hi,
>>>>> I have been using ms4w for quite some time and have discovered problems
>>>>> with Oracle when using php_mapscript. I posted this problem at ms4w's
>>>>> support and was adviced to turn to you.
>>>>> I am supporting a gis-system on the web that is heavily database
>>>>> dependent, and can run on either postgres or oracle according to the
>>>>> costumer's request. So there are two sets of php-scripts that are
>>>>> identical apart from the database calls.
>>>>> Thera are no problems with postgres.
>>>>> With Oracle there is a funny problem with filter.
>>>>> Look at this:
>>>>> foreach($aLayersIdx as $layerIndex) {
>>>>> $oLayerK = $oMapK->getLayer($layerIndex);
>>>>> if ($bDebug) {
>>>>> fwrite($f,"layer: ".$oLayerK->name."\r\n");
>>>>> if ($oLayerK->name == "AVD" && $avd == "") {
>>>>> $oLayerK->set("status",MS_OFF);
>>>>> continue;
>>>>> $filter = "";
>>>>> switch ($oLayerK->name) {
>>>>> case "AVD" :
>>>>> $filter = "([ORGID]='".$orgid."' AND [FV]='".$fv."' AND
>>>>> [BEV]='".$bev."' AND [SKIFTE]='".$skifte."' AND [AVD]='".$avd."')";
>>>>> $data = "KARTOBJ_SDO FROM ".$dbowner.".AVD*AVD";
>>>>> break;
>>>>> case "X" :
>>>>> $data = "KARTOBJ_SDO FROM ".$dbowner.".KARTA*TMP2";
>>>>> break;
>>>>> $data = str_replace("*","$",$data);
>>>>> $oLayerK->set("data", $data);
>>>>> $oLayerK->setFilter($filter);
>>>>> $oLayerK->setConnectionType(MS_ORACLESPATIAL);
>>>>> $oLayerK->set("connection", $conn);
>>>>> $oLayerK->set("status", MS_ON);
>>>>> if ($bDebug) {
>>>>> fwrite($f,"connection: ".$conn."\r\n");
>>>>> fwrite($f,"filter: ".$filter."\r\n");
>>>>> fwrite($f,"data: ".$data."\r\n");
>>>>> A mapfile with two layers, 'AVD' and 'X'.
>>>>> Problem is that filter for layer 'X' does not work. Or, rather, it works
>>>>> but no record is returned. The mapserver debugger reports no error.
>>>>> The filter for layer 'AVD' works fine.
>>>>> When the line $filter = "[ID]='".$sessid."')" is commented and the table
>>>>> KARTA$TMP2 contains only one record it works and a map layer is produced.
>>>>> So it seems that when filter is introduced in the select something goes
>>>>> wrong.
>>>>> I thought that ID might be a reserved word but after some testing I found
>>>>> that filter fails in calls to other tables as well.
>>>>> For example:
>>>>> This works
>>>>> [BEV]='".$bev."')";
>>>>> But this does not work
>>>>> [BEV]='".$bev."' AND [SKIFTE]='".$skifte."')";
>>>>> The problem is consistent in that way that where the problem occurs it
>>>>> always occurs, and where it not occurs it never occurs. It is not
>>>>> intermittent.
>>>>> The php script ( where the snippet came from above ) was developed under
>>>>> ms4w version 2.2.7 and at that time no problems occured. I have also used
>>>>> version 3.0.6 and 3.1.1 and both versions have problems. So somewhere
>>>>> between 2.2.7 and 3.0.6 something happened.
>>>>> I am at loss here.
>>>>> Björn Danielsson
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20160118/9e8610bd/attachment-0001.html>
