[mapserver-dev] [EXTERNAL] Problem with filter in Oracle
Björn Danielsson
bjorn.danielsson at falubo.se
Wed Jan 20 02:55:14 PST 2016
Sorry about that, here is a new set.
It did not work either.
Map file:
MAP
NAME "C2"
IMAGETYPE JPEG
EXTENT 1449000 6849000 1456000 6859000
SIZE 500 500
UNITS METERS
# SHAPEPATH "c:\TMP\"
IMAGECOLOR 255 255 255
FONTSET "c:\data\mapserverfonts\fonts.list"
DEBUG 5
CONFIG "MS_ERRORFILE" "/ms4w/tmp/ms_error.txt"
OUTPUTFORMAT
NAME "jpeg"
DRIVER AGG/JPEG
MIMETYPE "image/jpeg"
IMAGEMODE RGB
EXTENSION "jpg"
FORMATOPTION "GAMMA=0.75"
END
LAYER
NAME "X"
GROUP "X"
CONNECTIONTYPE oraclespatial
CONNECTION "c2/c2a@//192.168.0.101/fwt"
# DATA KARTOBJ_SDO FROM c2.KARTA$TMP2 WHERE SDO_FILTER(
KARTOBJ_SDO, MDSYS.SDO_GEOMETRY(2003, -1,
NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),SDO_ORDINATE_ARRAY(393339,6773950,394169,6774780)),'querytype=window')
= 'TRUE'
DATA "KARTOBJ_SDO FROM c2.KARTA$TMP2"
FILTER ("[ID]"="BJDA1")
STATUS ON
TYPE POLYGON
MINSCALEDENOM 2000
MAXSCALEDENOM 5000000
DEBUG 5
CLASS
STYLE
OUTLINECOLOR 255 0 0
END
END
END
END
Debug:
[Wed Jan 20 11:46:47 2016].919000 msDrawMap(): rendering using outputformat
named jpeg (AGG/JPEG).
[Wed Jan 20 11:46:47 2016].919000 msDrawMap(): WMS/WFS set-up and query,
0.000s
[Wed Jan 20 11:46:47 2016].919000 msOracleSpatialLayerOpen called with:
KARTOBJ_SDO FROM c2.KARTA$TMP2 (Layer pointer 086AB118)
[Wed Jan 20 11:46:47 2016].950000 msOracleSpatialLayerOpen. Shared
connection not available. Creating one.
msConnPoolRegister(X,c2/c2a@//192.168.0.101/fwt,0DA8F108)
[Wed Jan 20 11:46:47 2016].950000 msOracleSpatialLayerFreeItemInfo was
called.
[Wed Jan 20 11:46:47 2016].950000 msOracleSpatialLayerInitItemInfo was
called.
[Wed Jan 20 11:46:47 2016].950000 msOracleSpatialLayerTranslateFilter.
String: "[ID]"="BJDA1"
[Wed Jan 20 11:46:47 2016].950000 msOracleSpatialLayerTranslateFilter. There
are tokens to process
[Wed Jan 20 11:46:47 2016].950000 total filter tokens are 3
,[Wed Jan 20 11:46:47 2016].950000 msOracleSpatialLayerWhichShapes was
called.
[Wed Jan 20 11:46:47 2016].950000 msOracleSpatialLayerWhichShapes. Using
this Sql to retrieve the data: SELECT ID, rownum, KARTOBJ_SDO FROM
c2.KARTA$TMP2 WHERE ID = 'BJDA1' AND SDO_FILTER( KARTOBJ_SDO,
MDSYS.SDO_GEOMETRY(2003, :srid,
NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),:ordinates),'querytype=window') =
'TRUE'
[Wed Jan 20 11:46:47 2016].950000 msOracleSpatialLayerWhichShapes. Bind
values: srid:-1 minx:393339.500000 miny:6773950.000000
maxx:394169.500000 maxy:6774780.000000
[Wed Jan 20 11:46:47 2016].950000 msOracleSpatialLayerWhichShapes getting
ordinate definition.
[Wed Jan 20 11:46:47 2016].950000 msOracleSpatialLayerWhichShapes converting
to OCIColl.
[Wed Jan 20 11:46:47 2016].950000 msOracleSpatialLayerWhichShapes bind by
name and object.
[Wed Jan 20 11:46:47 2016].950000 msOracleSpatialLayerWhichShapes name and
object now bound.
[Wed Jan 20 11:46:47 2016].965000 msOracleSpatialLayerFreeItemInfo was
called.
[Wed Jan 20 11:46:47 2016].965000 msOracleSpatialLayerClose was called.
Layer: 086AB118, Layer name: X
[Wed Jan 20 11:46:47 2016].965000 msOracleSpatialLayerClose. Cleaning
layerinfo handlers.
[Wed Jan 20 11:46:47 2016].965000 msOracleSpatialLayerClose. Release the
Oracle Pool.
msConnPoolRelease(X,c2/c2a@//192.168.0.101/fwt,0DA8F108)
msConnPoolClose(c2/c2a@//192.168.0.101/fwt,0DA8F108)
[Wed Jan 20 11:46:47 2016].965000 msDrawMap(): Layer 0 (X), 0.046s
[Wed Jan 20 11:46:47 2016].965000 msDrawMap(): Drawing Label Cache, 0.000s
[Wed Jan 20 11:46:47 2016].965000 msDrawMap() total time: 0.046s
[Wed Jan 20 11:46:47 2016].997000 msFreeMap(): freeing map at 086A4BC0.
[Wed Jan 20 11:46:47 2016].997000 msOracleSpatialLayerClose was called.
[Wed Jan 20 11:46:47 2016].997000 freeLayer(): freeing layer at 086AB118.
Björn D
-----Original Message-----
To: Björn Danielsson <bjorn.danielsson at falubo.se>
Cc: Michael Smith <michael.smith.erdc at gmail.com>, MapServer Dev Mailing
List <mapserver-dev at lists.osgeo.org>
Date: Wed, 20 Jan 2016 10:41:12 +0100
Subject: Re: [mapserver-dev] [EXTERNAL] Problem with filter in Oracle
FILTER "([ID='BJDA1')"
Same result. Does not work with filter active, works when the filter line is
commented.
Your FILTER line is syntactically incorrect. Try with
if using Mapserver 7, or
FILTER "ID='BJDA1'"
for mapserver < 7
thomas
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20160120/943843c7/attachment.html>
