[mapserver-dev] Fwd: Considering a new WMS/WMTS output format: jpeg or png (JPENG for friends)
Andrea Aime
andrea.aime at geo-solutions.it
Sun Jun 26 12:57:13 PDT 2016
in case it is of interest, after discussion on the geosever list we went for
a image/vnd.jpeg-png mime type, to place it in the vendor tree, since it's
not
a recognized IANA mime:
https://en.wikipedia.org/wiki/Media_type#Vendor_tree
Cheers
Andrea
On Sun, Jun 26, 2016 at 9:36 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Le mardi 07 juin 2016 19:59:19, Even Rouault a écrit :
> > On Tuesday 07 June 2016 14:32:21 Jeff McKenna wrote:
> > > Forwarding interesting idea on the GeoServer-devel list. Seems like
> > > something that would interest MapServer-ers serving through WMS as
> well.
> > Sounds like a good idea.
> I've a proposed implementation for this idea in
> https://github.com/mapserver/mapserver/pull/5296
> Works well in my few tests in WMS & WCS (are there other code paths where
> that
> should be added ?)
> I've added by default image/jpeg-png and image/jpeg-png8 (which currently
> breaks GetCapabilities expected response). Could also be let to user
> choice to
> enable them.
> This is generic enough so that custom formats can be defined by the user to
> potentially use different levels of JPEG compression, use GDAL drivers,
> etc..
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 339 8844549
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20160626/a39e16aa/attachment.html>
