[mapserver-dev] Fwd: Considering a new WMS/WMTS output format: jpeg or png (JPENG for friends)
Even Rouault
even.rouault at spatialys.com
Sun Jun 26 12:36:30 PDT 2016
Le mardi 07 juin 2016 19:59:19, Even Rouault a écrit :
> On Tuesday 07 June 2016 14:32:21 Jeff McKenna wrote:
> > Forwarding interesting idea on the GeoServer-devel list. Seems like
> > something that would interest MapServer-ers serving through WMS as well.
> Sounds like a good idea.
I've a proposed implementation for this idea in
https://github.com/mapserver/mapserver/pull/5296
Works well in my few tests in WMS & WCS (are there other code paths where that
should be added ?)
I've added by default image/jpeg-png and image/jpeg-png8 (which currently
breaks GetCapabilities expected response). Could also be let to user choice to
enable them.
This is generic enough so that custom formats can be defined by the user to
potentially use different levels of JPEG compression, use GDAL drivers, etc..
Even
http://www.spatialys.com
