[mapserver-dev] Layer opacity is not being saved with mapserver-7-0
Tamas Szekeres szekerest at gmail.com
Wed May 18 08:59:01 PDT 2016
Hi All,
As far as I see the layer opacity setting is not saved by mapserver to the
map file in the 7-0 branch, though it is saved in the master branch.
In the 7-0 branch , when I set the opacity in the map file manually as
follows:
LAYER
  COMPOSITE
      OPACITY 70
  END
END
the application is crashing when loading that map file. This is because the
temp image created has null map reference and the truetype font (hashtable)
lookup causes the crash.
Any ideas to fix this?
Thanks,
Tamas
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20160518/c7122214/attachment.html>
